12 Replies Latest reply on Oct 28, 2009 8:18 AM by Tareq_1993
    Condition (if)
      I've made 2 boxes
      1 dynamic called (Result)
      and 1 input called (Enter)
      I want a condition, if Enter is bigger than 0 I get result big, if it was less, I get result small, if it equals 0 I get result medium.
      How can that be scripted?
      (Flash CS4, action script 2)
      thanks alot
        • 1. Re: Condition (if)
          I am not sure what you mean when you say 2 boxes, but if they are textfields, then you will refer to what's in them using textFieldName.text, where textFieldName is whatever instance name you assign
          if(Enter < 0){
               Result = "small";
          } else if(Enter > 0){
               Result = "big";
          } else {
               Result = "medium";
          • 2. Re: Condition (if)
            Tareq_1993 Level 1
            thanks for trying to help.
            But, it gave all the time answer Medium, so I tried to remove the third choice.
            After I've done that, it was leaving the dynamic box blank (no answer)
            so I dun know why is that....
            Can you help please?...
            and yea, they r text fields, one of them u insert a number inside, and the other is dynamic box, the result should appear in.
            • 3. Re: Condition (if)
              What makes the result appear?  Do you click a button?  HAve you assigned instance names to the textfields via the properties panel?
              • 4. Re: Condition (if)
                There is no telling what you have created and what code you might need to use as a result.  I have created an example file for you.  Study it to see what I did for the textfields and how I acquire, test, and assign the values.
                There are a variety of ways one could approach this, so I don't expect what I did will match what you are doing, but at least you will have something that works that you might be able to build from.
                • 5. Re: Condition (if)
                  Tareq_1993 Level 1
                  Thanks alot.
                  It really worked.
                  The different thing I was doing, is, I was putting var name, instead of instance name.
                  Anyway, what's the difference between var name and instance name?
                  Thanks alot.
                  • 6. Re: Condition (if)
                    The var name is what it implies, it is a variable that gets associated with the textfield text entry as a value.  The text property is a String value of what is contained in the textfield.  It is generally a better practice to avoid using the var as it doesn't always behave as expected... using the text property is much more reliable.
                    • 7. Re: Condition (if)
                      Tareq_1993 Level 1
                      Although I didn't understand what you meant.
                      But, thanks alot
                      One more simple question, and here my steps might end.
                      You have replied to my past posts, and I consider you may know what I was, and still, trying to do.
                      4 input boxes.
                      North - South - East - West.
                      4 Dynamic Boxes
                      Fx - Fy - Ft - Fc
                      Fx = East - West
                      Fy =  North - South
                      Ft = root (power 2 (Fx) + (power 2 (Fu))
                      if (Ft>0)
                      Fc = Big
                      else if (Ft<0)
                      Fc = Small
                      Fc = medium
                      I've tried alot, in over 15 different coding way, but it didn't work.
                      instance and var thing really confuse me.
                      However, if 1 step works, the other doesn;t.
                      But seperately they work perfect.
                      So, can you instuct me and put me on the right way?
                      or Just do me a basic code, and ill understand it
                      thanks alot
                      • 8. Re: Condition (if)
                        Tareq_1993 Level 1
                        errrrr mate?
                        its ok, dun give me full code, just tell me way to make if conditions using var name, without using instance, thanks alot
                        • 9. Re: Condition (if)
                          Errr... why would you expect me to create the full code for anything for you--your last "simple question" seemed more like a task to create the code for your complete design... well beyond the scope of your original posting and my intentions in helping in these forums.
                          I won't show you how to use the var name approach because I do not promote using var names for textfields... they are unreliable.
                          • 10. Re: Condition (if)
                            Tareq_1993 Level 1
                            Sorry mate, since I am not native, maybe what I wrote isn't exactly what I meant.
                            I meant, instead of keep trying and we get no results, u can save ur time.
                            Not task at all.
                            Well, I;ve tried many ways, but, I do the mathematical stuff using var name, and u showed me how to do (if) using instance name.
                            so, I cant make all that in one scene, which I want.
                            so now, either I learn how to do mathmatics (+ / pow / square root) using instance.
                            Or just learn how to do (if) conditions using var.
                            And thanks alot by the way, you have helped me much so far.
                            • 11. Re: Condition (if)
                              I always avoid using the var option for textfields.  If I need to use variables from textfields I create them separately as variables and assign the textfield.text value to them.  If it is a number in the textfield I will assign it by casting it as a number value... example
                              var someVariable1 = Number(textfield1.text);
                              var someVariable2 = Number(textfield2.text);
                              var someVariable3 = someVariable1 + someVariable2;
                              • 12. Re: Condition (if)
                                Tareq_1993 Level 1
                                I appreciate you try to help me.
                                I tried to create one, but the dynamic field was being still empty, didn't get any answer in it. you can see it:
                                thanks alot
