2 Replies Latest reply on Oct 27, 2009 2:22 AM by S.Biancardo
    Font Select
    S.Biancardo Level 1
      Hi, i have this problem when i run a scrit and create a style i want to select a otf font but if is pre-select the script run else if i don't pre-select scritp indesign return error:
           Font Family request is not avaiable
        • 1. Re: Font Select
          Can you (at the very least!) show how you select this font? It seems that your command isn't doing anything -- if it only works if you select the font manually but it doesn't if you don't.
          Perhaps your initial combination of font and style is not valid? For example, this
          app.selection[0].insertionPoints[-1].fontStyle = "65 Bold";
          will not work if the selected base font is not Univers. One way to select an entire font plus style is
          app.selection[0].insertionPoints[-1].appliedFont = app.fonts.item("Univers LT Std\t65 Bold");
          -- note the TAB inbetween the font family and style name.
          • 2. Re: Font Select
            S.Biancardo Level 1
            I create a style:
            var style = app.activeDocument.paragraphStyles.add();
            Then i select fontFamily
            style.appliedFont = "Helvetica Neue LT Std";
            But if i don't preselect font indesign return FontFamily request is not avaiable.
            Preselect is select font by Select.
            It function if i insert a param String but if i insert by a variables it return FontFamily not avaiable:
            var font = "Helvetica Neue LT Std";
            style.appliedFont = app.fonts.item(font);
            I am very stupid....
            Thank's.
