0 Replies Latest reply on Oct 26, 2009 10:41 AM by kevinklin
    [svn:fx-trunk] 11151: Various bug fixes.
    kevinklin Adobe Employee
      Revision: 11151
      Author:   klin@adobe.com
      Date:     2009-10-26 10:41:10 -0700 (Mon, 26 Oct 2009)
      Log Message:
      Various bug fixes.
      Button.as
      -Added some ASDocs for a previous fix where we made the icons property protected instead of private.
      Skins.properties, components.properties, sparkEffects.properties
      -Removed ?\226?\128?\156Fx?\226?\128?\157 prefix and cleaned up whitespace
      SwatchPanel.as, defaults.css
      -ColorPicker was drawing incorrectly with sparkskins because two halo specific styles were missing in the spark theme. Thus, I included highlightColor and shadowColor?\194?\160into the spark theme and added them to defaults.css.
      TitleWindowSkin.mxml, wireframe/TitleWindowSkin.mxml
      -The label skin part came too close to the close button so I added padding
      DataGrid.as
      -Added exclude metadata for columnWidth
      -Column widths are now rounded down to avoid sub-pixel values in the initial rendering
      QE notes: None
      Doc notes: None
      Bugs: SDK-23057, SDK-23695, SDK-23576, SDK-23791, SDK-22733, SDK-22757
      Reviewer: Glenn
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23057
          http://bugs.adobe.com/jira/browse/SDK-23695
          http://bugs.adobe.com/jira/browse/SDK-23576
          http://bugs.adobe.com/jira/browse/SDK-23791
          http://bugs.adobe.com/jira/browse/SDK-22733
          http://bugs.adobe.com/jira/browse/SDK-22757
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/en_US/skins.properties
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DataGrid.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/colorPickerClasses/SwatchPan el.as
          flex/sdk/trunk/frameworks/projects/spark/bundles/en_US/components.properties
          flex/sdk/trunk/frameworks/projects/spark/bundles/en_US/sparkEffects.properties
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TitleWindowSkin.mx ml
