0 Replies Latest reply on Oct 26, 2009 11:12 AM by JCDietz
    Issues with Flex Web Services code - Cannot Marshall
      I'm starting to get the feeling that the Flex Web Services autogenerated code isn't that widely used, I've already run into a few problems with the autogenerated code with WSDL's that work fine in other platforms.  My current issue is in trying to send a complex type as a parameter to a web service.
      The parameter is defined as:
      <xsd:element name="SiteCategoriesParameters">
                      <xsd:choice maxOccurs="1" minOccurs="1">                </xsd:choice>
      This generates an object called SiteCategoriesParametersChoice_type0 that the service call expects to be passed.  When I make that call I get an error that says "Type Error: Cannot marshall type 'http://www.w3.org/2001/XMLSchema::SiteCategoriesParametersChoice_type0' to simple content".  I can't seem to get around this error without changing the WSDL, regardless of what kind of data I use to create the SiteCategoeisParametersChoice_type0 object.
      Any ideas?  Are there any groups or discussions specifically for using the WebServices generated code?
      John Dietz
