0 Replies Latest reply on Oct 26, 2009 11:26 AM by CoreyRLucier
    [svn:fx-trunk] 11154: Adding support for -minimum-supported-version.
    CoreyRLucier Adobe Employee
      Revision: 11154
      Author:   clucier@adobe.com
      Date:     2009-10-26 11:26:26 -0700 (Mon, 26 Oct 2009)
      Log Message:
      Adding support for -minimum-supported-version.  We now exclude spark.swc, sparkskins.swc, and spark_rb.swc from linkage when compatibility-version is < 4.0.0.  Please see https://zerowing.corp.adobe.com/display/flex/CompatibilityModeSWC+Policy
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Paul
      Tests run: Checkin
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/build.xml
          flex/sdk/trunk/frameworks/projects/sparkskins/build.xml
          flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Versions.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/CatalogReader.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/catalog/CatalogWriter.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
