0 Replies Latest reply on Oct 26, 2009 1:35 PM by Darrell Loverin
    [svn:fx-trunk] 11163: Changes to turn on the per-module style feature by default.
    Darrell Loverin Level 4
      Revision: 11163
      Author:   dloverin@adobe.com
      Date:     2009-10-26 13:35:33 -0700 (Mon, 26 Oct 2009)
      Log Message:
      The feature can be turned off by compiling with -isolateStyles=false.
      QE notes: None.
      Doc notes: None.
      Bugs:
      Reviewer: Alex, Paul
      Tests run: checkintests, all mustella
      Is noteworthy for integration: Yes.
      Summary of changes:
      frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
      Propagate the module factory in setFlexContent.
      frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
      Implement IFlexModule
      frameworks/projects/framework/src/mx/containers/ApplicationControlBar.as
      Move getting style declaration from the constructor to the override of the module factory setter.
      frameworks/projects/framework/src/mx/controls/Alert.as
      Set moduleFactory to parent if parent is an IFlexModuleFactory.
      frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItemRenderer.as
      Pass styleManager in CSSStyleDeclaration.
      frameworks/projects/framework/src/mx/controls/menuClasses/MenuBarItem.as
      frameworks/projects/framework/src/mx/controls/RadioButton.as
      frameworks/projects/framework/src/mx/controls/SWFLoader.as
      Handle the ?\226?\128?\156get parent module factory?\226?\128?\157 request from an embedded swf.
      frameworks/projects/framework/src/mx/core/Container.as
      frameworks/projects/framework/src/mx/core/UIComponent.as
      Defer setting styles until a module factory is set.
      frameworks/projects/framework/src/mx/managers/systemClasses/ChildManager.as
      Set the module factory of an added child.
      frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
      Set the module factory of the tooltip to be the same as the target.
      frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
      Rename parameter based on PARB feedback.
      frameworks/projects/framework/src/mx/styles/IStyleModule.as
      Add setStyleDeclarations per spec.
      frameworks/projects/framework/src/mx/styles/StyleManager.as
      Deprecate old static StyleManager API.
      frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
      Use IStyleModule.setStyleDeclarations.
      frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      A fix to get the correct style manager and pass styleManager in CSSStyleDeclaration.
      frameworks/projects/spark/src/mx/controls/dataGridClasses/FTEDataGridItemRenderer.as
      frameworks/projects/spark/src/spark/components/Group.as
      Propagate moduleFactory in elementAdded().
      modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      Rename ?\226?\128?\147create-style-manager option to ?\226?\128?\147isloateStyles. The option has been changed from hidden to advanced.
      modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
      Fix bug to not add a default factory that is not needed.
      modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
      Initialize styles in a module factory setter override.
      modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      Changed emitComponentInitializers_1 to not emit style related code if the document implements IFlexModule. Created emitComponentStyleInitializers to emit those styles.
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Generate code to match ClassDef.vm and ClassDefLib.vm changes.
      modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      Add IFlexModuleFactory to standard imports.
      modules/compiler/src/java/flex2/configuration_en.properties
      modules/compiler/src/java/flex2/tools/PreLink.java
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/FlexContentHolder.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/ApplicationControlBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Alert.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/RadioButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/menuClasses/MenuBarItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/ToolTipManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/ChildManager.a s
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/ModuleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleModule.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/controls/dataGridClasses/FTEDataGridItemR enderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
