0 Replies Latest reply on Oct 26, 2009 3:22 PM by Peter Farland
    [svn:fx-trunk] 11169: Adding placeholder ASDoc for release engineering to build a resource bundle to accompany playerglobal .swc.
    Peter Farland Level 3
      Revision: 11169
      Author:   pfarland@adobe.com
      Date:     2009-10-26 15:22:16 -0700 (Mon, 26 Oct 2009)
      Log Message:
      Adding placeholder ASDoc for release engineering to build a resource bundle to accompany playerglobal.swc.
      QE notes: N/A
      Doc notes: N/A
      Bugs: N/A
      Reviewer: David Z
      Tests run: N/A
      Is noteworthy for integration: No
      Added Paths:
          flex/sdk/trunk/frameworks/projects/playerglobal/
          flex/sdk/trunk/frameworks/projects/playerglobal/build.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/de_DE/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/de_DE/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/__Global__.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.accessibility.xm l
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.data.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.desktop.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.display.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.errors.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.external.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filesystem.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filters.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.geom.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.html.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.media.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.drm.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.printing.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.profiler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.sampler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.security.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.system.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.engine.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.ui.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.utils.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.xml.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/packages.dita
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/packages.dita.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/empty.properties
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/fr_FR/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/fr_FR/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/ja_JP/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/ja_JP/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/ru_RU/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/ru_RU/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/zh_CN/
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/zh_CN/docs/
          flex/sdk/trunk/frameworks/projects/playerglobal/src/
          flex/sdk/trunk/frameworks/projects/playerglobal/src/Empty.as
