0 Replies Latest reply on Oct 26, 2009 4:15 PM by rfrishbe
    [svn:fx-trunk] 11170: ItemRenderer changes.
    rfrishbe Level 3
      Revision: 11170
      Author:   rfrishbe@adobe.com
      Date:     2009-10-26 16:15:30 -0700 (Mon, 26 Oct 2009)
      Log Message:
      ItemRenderer changes.  Fixing some bugs with the autoDrawBackground flag.  Also making some PARB changes:
      1.  IItemRenderer.index -> itemIndex (affects DefaultItemRenderer, ItemRenderer, and ButtonBarButton).
      2.  GroupBase.renderBackgroundFill() (protected method) -> drawBackground() (mx_internal method)
      3.  ItemRenderer.handleBackgroundFill -> autoDrawBackground
      4.  Removed contentBackgroundColor from ItemRenderer
      Also, DefaultItemRenderer is now no longer an MXML file, but it is an AS-only class that extends UIComponent.
      QE notes: -
      Doc notes: Yes - Can you please look at the ASDocs for DefaultItemRenderer.as and the autoDrawBackground flag on ItemRenderer
      Bugs: -
      Reviewer: Deepa
      Tests run: checkintests, Mustella List, DataGroup, DropDownList
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBarButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DataGroup.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/IItemRenderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ItemRenderer .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultComplexItemRenderer .mxml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultItemRenderer.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultItemRenderer.mxml
