3 Replies Latest reply on Oct 27, 2009 4:05 AM by jake_flex
    Braces { } in blue bold possible?
    timo888 Level 1
      My new glasses don't have as ideal a focal distance for computer work as my prior pair did, and I'm finding it a little hard to distinguish parenthesis from brace. Until I get a new pair of glasses, is it possible to have { } automatically appear in blue bold in the Flex Builder source code editor?
      if (visible) {
        • 1. Re: Braces { } in blue bold possible?
          injpix Level 3
          Yes, you can.   In FlashBuilder goto:
          Window>Preferences>FlashBuilder>Editors>Syntax Coloring>ActionScript>Bracket/Brace
          When you are there, you can tick the appropriate checkbox and select color.
          • 2. Re: Braces { } in blue bold possible?
            timo888 Level 1
            Thanks for the tip.
            Although I was hoping to apply the styles to { } only, whatever gets applied to { } also gets applied to ( ). Still, bolding them both makes them both a little easier to see, and I've found a different font where {} and () are much easier to tell apart than they are in Courier.
            • 3. Re: Braces { } in blue bold possible?
              jake_flex Level 2
              A bit of topic, but still related to braces/parenthesis in Flex Builder.
              How come the matching parenthesis is not highlighted in Flex Builder? In the preferences, there's an option called 'Highlight matching braces'. That only mathes the { } characters.
              For Java editor, there's an option called 'Highlight matching brackets', which matches all, {}, (), [] and <>.
