3 Replies Latest reply on Oct 27, 2009 10:17 AM by Luke Jennings
    Illustrator Drop Shadow Problems!
    MarkAspro
      Whenever I get customer artwork with drop shadows created in Illustrator 4 the rip (Onyx) interpretes a box around the item (in shadowy white).  I tried (Effects>Document Raster Effects Settings>Options>Add space around object) but that doesn't seem to help. I put 5 inches in as the value with no change. Does anyone have any idea? I will also add that I am in the sign industry.  Is it best to avoid raster effects altogether in large format printing?
        • 1. Re: Illustrator Drop Shadow Problems!
          Sounds more like an issue with the RIP and its driver or flattening the appearance in general. I would investigate how it actually interprets your file. I'm sure this is simply something with flipping a switch for transparency handling or sending the file in a different format to the RIP, e.g. choosing a different PDF language level.
          Mylenium
          • 2. Re: Illustrator Drop Shadow Problems!
            Aldo Roldan
            Dude the only way to make it work is to export the file as a tif and that is the only way!!
            I hate it too when i get illustrator files with drop shadows and filter effects. It never comes out the way it's supposed to!!
            If they want drop shadows they should use photoshop and save the printer the headache!
            • 3. Re: Illustrator Drop Shadow Problems!
              Luke Jennings Adobe Community Professional
              There is no need to avoid raster effects, just be sure to select an adequate resolution (300 for print)
              You want your shadow (most likely black) to overprint everything under it. If your rip won't handle a PDF with transparency properly, one work around is to set the object and its shadow to multiply, duplicate the object, then remove the shadow and set it to normal (not multiply). Flatten the PDF only as a last resort.
