8 Replies Latest reply on Oct 27, 2009 9:15 AM by Steven..
    [JS][CS3] Simple dialog box problem
    Roy Marshall Level 1
      Hi
      I am wanting to make my script do 1 of 2 things depending on the result of a dialog box.  I cannot seem to register the users response.  Here is the code:
      var myDialog = new Window('dialog', 'Confirm Changes');
      myDialog.frameLocation = [600,400];
      myDialog.size = [590, 250];
      myImage = myDialog.add('image',[480,41,572,127],'/Macintosh HD/Applications/Adobe InDesign CS3/Scripts/Scripts Panel/Images/xxxx.png');
      myPanel= myDialog.add('panel', [10,10,580,240], 'Select the action you wish to use');
      //Adding Buttons
      myUseExistingTextButton = myPanel.add('button', [48,190,75,25], 'Use Existing Text',{name:'select'});
      myUseNewButton = myPanel.add('button', [260,190,75,25], 'Use New text as shown',{name:'select'});
      myCancelButton = myPanel.add('button', [480,190,75,25], 'Cancel',{name:'select'});
      myExistingTextWindow = myDialog.add('edittext',[20,40,230,200],'Existing Text');
      myNewTextWindow = myDialog.add("edittext",[250,40,460,200],"New Text");
      myResult = myDialog.show();
      if(myResult == true)
           if (myResult == 0)
                          alert("Old was selected");
           if (myResult == 1)
                          alert("New was selected");
      which gives the following result:
      All I want to do is use the selected button do do the next part of my script depending on the text selected.
      I will keep on looking, and di-secting other scripts, but any help here would be nice.
      Thanks as always
      Roy
        • 1. Re: [JS][CS3] Simple dialog box problem
          Steven.. Level 3
          Your code is messed up. The coordinates make no sense.
          I changed it just to get some of the picture
          //myImage = myDialog.add('image',[480,41,572,127],'/Macintosh HD/Applications/Adobe InDesign CS3/Scripts/Scripts Panel/Images/xxxx.png');
          //Adding Buttons
          var myUseExistingTextButton = myPanel.add('button', [48,190,188,220], 'Use Existing Text',{name:'select'});
          var myUseNewButton = myPanel.add('button', [260,190,360,220], 'Use New text as shown',{name:'select'});
          var myCancelButton = myPanel.add('button', [480,190,575,220], 'Cancel',{name:'select'});
          var myExistingTextWindow = myPanel.add('edittext',[20,40,230,180],'Existing Text');
          var myNewTextWindow = myPanel.add("edittext",[250,40,460,180],"New Text");
          myDialog.show();
          Anyways, there is no way in your code defining what happens when button is clicked. why should one button be 0 and the other 1. Where did you define that.
          You need an click event for each button, which exits dialog and defines what to do for that button etc..
          • 2. Re: [JS][CS3] Simple dialog box problem
            Thank you Steven for your reply.
            I admit I often go around the houses, but the dialog box I was making was all good with the co-ordinates I was using.
            I was stuck on the actions for the buttons as I said in my post, and that is where I was needing assistance.  I will look at your code, and no doubt use it for my needs.
            Thanks again for your very quick response, I am constantly amazed by this forum.
            Cheers
            Roy
            • 3. Re: [JS][CS3] Simple dialog box problem
              Can anyone let me know how to add the 'onClick. command to carry out the selected function?  I will keep looking in the meantime.
              Cheers
              Roy
              • 4. Re: [JS][CS3] Simple dialog box problem
                Thomas B. Nielsen Level 3
                myButton.onClick = function(){
                                        alert("You clicked the button!");
                or
                myButton.onClick = myFunction;
                function myFunction () {
                Thomas B. Nielsen
                http://www.lund-co.dk
                • 5. Re: [JS][CS3] Simple dialog box problem
                  Thanks for that Thomas.
                  Quite simple really, but unless you know it....
                  Anyway, I am getting a runtime error when I add the destroy() line for the dialog:
                  function ExistingText()
                  alert("Use Existing Text");
                  myDialog.destroy();
                  I have used this before but I guess not with ScriptUI. Should I use something else?
                  Cheers
                  Roy
                  • 6. Re: [JS][CS3] Simple dialog box problem
                    I have been trying lots of options, and myDialog.close(); does it!
                    Cheers
                    Roy
                    • 7. Re: [JS][CS3] Simple dialog box problem
                      Hi.
                      One more little thing, when I use this line below, the variable 'myPara2.contents' does not wrap in the box.  Is there a property I need to change to allow this?
                      var myExistingTextWindow = myPanel.add('edittext',[20,20,230,180],myPara2.contents);
                      Cheers
                      Roy
                      • 8. Re: [JS][CS3] Simple dialog box problem
                        Steven.. Level 3
                        Here is code created with RapidScriptUI in about 2 minutes. It includes multiline editbox, dimensions without using co-ordinates  that display accurately cross platform and simple to edit code for beginners like you to learn and understand (This is a free advertisement).
                        var rapidDlg = new Window('dialog',"Confirm Changes",undefined);
                        buildWindow();
                        rapidDlg.show();
                        function buildWindow(){
                        // Properties for rapidDlg.Panel1
                             rapidDlg.Panel1 = rapidDlg.add('panel',undefined,"Select the action you wish to choose");
                             rapidDlg.Panel1.margins= [20,20,20,20];
                             rapidDlg.Panel1.orientation = "row";
                        // Properties for rapidDlg.Panel1.Group1
                             rapidDlg.Panel1.Group1 = rapidDlg.Panel1.add('group',undefined);
                             rapidDlg.Panel1.Group1.orientation = "column";
                        // Properties for rapidDlg.Panel1.Group1.EditText1
                             rapidDlg.Panel1.Group1.EditText1 = rapidDlg.Panel1.Group1.add('edittext',undefined,"Existing Text", {multiline:true});
                             rapidDlg.Panel1.Group1.EditText1.preferredSize.width = 200;
                             rapidDlg.Panel1.Group1.EditText1.preferredSize.height = 100;
                        // Properties for rapidDlg.Panel1.Group1.ExistingText
                             rapidDlg.Panel1.Group1.ExistingText = rapidDlg.Panel1.Group1.add('button',undefined,"Use Existing Text");
                        rapidDlg.Panel1.Group1.ExistingText.onClick = ExistingText_Clicked;
                        // Properties for rapidDlg.Panel1.Panel2
                             rapidDlg.Panel1.Panel2 = rapidDlg.Panel1.add('panel',undefined,undefined);
                             rapidDlg.Panel1.Panel2.alignment = [' ','fill'];
                        // Properties for rapidDlg.Panel1.Group2
                             rapidDlg.Panel1.Group2 = rapidDlg.Panel1.add('group',undefined);
                             rapidDlg.Panel1.Group2.orientation = "column";
                        // Properties for rapidDlg.Panel1.Group2.EditText2
                             rapidDlg.Panel1.Group2.EditText2 = rapidDlg.Panel1.Group2.add('edittext',undefined,"New Text", {multiline:true});
                             rapidDlg.Panel1.Group2.EditText2.preferredSize.width = 200;
                             rapidDlg.Panel1.Group2.EditText2.preferredSize.height = 100;
                        // Properties for rapidDlg.Panel1.Group2.NewText
                             rapidDlg.Panel1.Group2.NewText = rapidDlg.Panel1.Group2.add('button',undefined,"Use New text as shown");
                        rapidDlg.Panel1.Group2.NewText.onClick = NewText_Clicked;
                        // Properties for rapidDlg.Button3
                             rapidDlg.Button3 = rapidDlg.add('button',undefined,"Cancel", {name:"cancel"});
                             rapidDlg.Button3.alignment = ['right',' '];
                        function ExistingText_Clicked(){
                             alert(this.text +  ' was clicked!');
                        function NewText_Clicked(){
                        Steven
                        http://scriptui.com
