2 Replies Latest reply on Oct 28, 2009 9:05 AM by timo888
    error when following devnet code-behind example
    timo888 Level 1
      I want to use the designer to build the component but also pass the constructor some arguments, so code-behind seemed the way to go.  I'm trying to create something analogous to the example here, though my class extends TitleWindow, not Form, because I want it to be a popup:
      http://www.adobe.com/devnet/flex/quickstart/building_components_using_code_behind/
      but am getting a null reference error in the creationCompleteHandler -- submitButton is null:
          private function creationCompleteHandler (event:FlexEvent):void
                  submitButton.addEventListener(MouseEvent.CLICK, submitHandler);
      Yet the submit button is placed in the mxml and assigned an ID there:
      <OEUTIL:ArgsTest xmlns:mx="http://www.adobe.com/2006/mxml"   xmlns:OEUTIL="OEUTIL.*"    >
      <mx:Button id="submitButton" label="Button"/>
      </OEUTIL:ArgsTest>
      and variable submitButton is declared public inside the code-behind class (see below).  Should the button's click-eventhandler be wired up in the mxml? It's as though the button hasn't been created before the creationComplete event fires.
      package OEUTIL
          import mx.containers.TitleWindow;
          import mx.controls.Alert;
           import mx.events.FlexEvent;
          import mx.controls.Button;
           import flash.events.MouseEvent;
      public class ArgsTest extends TitleWindow
      public var submitButton:Button;
      private var _arg1: Array;
      private var _arg2:String;
      public function ArgsTest(arg1:Array, arg2:String)
                  super();
                  _arg1=arg1;
                  _arg2=arg2;
                  addEventListener(FlexEvent.CREATION_COMPLETE, creationCompleteHandler);
                              // why is submitButton  null?
      private function submitHandler (event:MouseEvent):void       {
                    Alert.show("arg1 length is " + _arg1.length.toString() + "  arg2=" + _arg2);
