0 Replies Latest reply on Oct 27, 2009 8:05 AM by Paul Reilly
    [svn:fx-trunk] 11179: * Weekly batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 11179
      Author:   preilly@adobe.com
      Date:     2009-10-27 08:05:06 -0700 (Tue, 27 Oct 2009)
      Log Message:
      • Weekly batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-23111, SDK-23262, SDK-17908, SDK-21737, SDK-23559
      Reviewer: Corey
      Tests run: full cyclone
      Is noteworthy for integration: no
      Code-level description of changes:
        frameworks/projects/framework/src/mx/binding/utils/ChangeWatcher.as
          Added isExecuting logic to prevent infinite recursion with two way
          bindings.  We have a check in the Bindable generated setter, but
          it fails, because "NaN !== NaN" is returning true.  Go figure.
        modules/swfutils/src/java/flash/util/StringUtils.java
          Tweaked formatString() to handle unicode characters and added
          unformatString() to do the opposite for direct AST generation.
        modules/compiler/src/java/flex2/compiler/Source.java
          Added shortName arg to the constructor used by the
          InterfaceCompiler for inline components.
        modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          Modified completeTwoWayBindings() to ensure the destination is
          Bindable.
        modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
          Modified "Node formatExpr()" to use StringUtils.unformatString()
          to mimic what ASC's scanner would have done if it had read in the
          value.
        modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          Modified addExcludeClassNode() to no longer set the line and
          column for the inlineExcludeNode and excludeTextNode, so they
          don't have warnings and errors reported for them.  I guess no one
          compiles the frameworks with -keep.  Otherwise, this would have
          blocked them.
          Modified createInlineComponentUnit() and createDefinitionUnit() to
          pass in the className, as the shortName, to the Source
          constructor.
        modules/antTasks/src/flex/ant/MxmlcTask.java
        modules/antTasks/src/flex/ant/CompcTask.java
        modules/antTasks/src/flex/ant/AsDocTask.java
          Added support for show-invalid-css-property-warnings option.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23111
          http://bugs.adobe.com/jira/browse/SDK-23262
          http://bugs.adobe.com/jira/browse/SDK-17908
          http://bugs.adobe.com/jira/browse/SDK-21737
          http://bugs.adobe.com/jira/browse/SDK-23559
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/utils/ChangeWatcher.as
          flex/sdk/trunk/modules/antTasks/src/flex/ant/AsDocTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
          flex/sdk/trunk/modules/swfutils/src/java/flash/util/StringUtils.java
