2 Replies Latest reply on Oct 27, 2009 12:38 PM by Gex14286
    Problems saving cs3
    Gex14286 Level 1
      Hi
      I have AI CS3 saved on the C drive of my master computer but for some reason whenever the slave comptuer is not on it will not save and gives me an error message saying illustrator has "encountered a problem and needs to close". Everything else works fine except for when it comes time to save, PS CS3 works fine and saves, as well as AI CS2. Any thoughts? Thanks!
        • 1. Re: Problems saving cs3
          Master? Slave? In any case, the error here is pretty clear: At the time of install, your "slave" computer was connected to the "master" and had one of its drives mapped to the main machine. That info then became permanently part of the install info and the active configuration, requiring the other machine to run. uninstall, use the CS3 Clean Script from teh support pages, re-install and do the first run with the otehr machine disconnected.
          Mylenium
          • 2. Re: Problems saving cs3
            Gex14286 Level 1
            Thank you! Sorry if my terminology is not correct.
