0 Replies Latest reply on Oct 27, 2009 11:26 AM by Cr99
    TweenEffect choppy in full screen
    Cr99 Level 1
      I am using the Distortion Effects from the following library:
      http://blogs.adobe.com/auhlmann/archives/2007/03/distortion_effe.html
      Specifically, I'm doing the cube rotation.  The app is a kiosk that just rotates every five seconds.  It works fine in a small window, but when I do it in full screen, it siezes up right as it's about to finish the rotation.  Sometimes it hangs noticibly for a second or two before completing, but then it does in fact complete eventually but it is extremely bad looking.  Is this just a problem with TweenEffect (which the CubeRotate class extends)?
      Here is the code which calls the CubeRotation:
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
      xmlns:controls="com.adobe.ac.controls.*" creationComplete="init()"
      applicationComplete="setFullscreen()" focusRect="false">
      <mx:Script>
      <![CDATA[
      import mx.core.UIComponent;
      import com.adobe.ac.mxeffects.CubeRotate;
      import mx.controls.Alert;
      private var stateTimer:Timer = new Timer(5000);
      public var current:UIComponent;
      public var cr:CubeRotate=new CubeRotate(current);
      private function init():void {
      current = pan1;
      private function setFullscreen():void {
      stage.displayState = StageDisplayState.FULL_SCREEN;
      stateTimer.addEventListener(TimerEvent.TIMER, timerChange);
      stateTimer.start();
      private function timerChange(e:TimerEvent):void {
      var sel:UIComponent = detailStack.getChildAt(stateTimer.currentCount %detailStack.numChildren) as UIComponent;
      cr=new CubeRotate(current);
      cr.siblings=[sel];
      cr.smooth=true;
      cr.duration=1000;
      cr.direction='LEFT';
      cr.play();
      current = sel;
      </mx:Script>
      <mx:ViewStack id="detailStack" creationPolicy="all" width="100%" height="100%">
      <mx:Panel id="pan1" name="one" width="100%" height="100%" title="Number 1" backgroundAlpha="0.4" backgroundColor="yellow"/>
      <mx:Panel id="pan2" name="two" width="100%" height="100%" title="Number 2" backgroundAlpha="0.4"  backgroundColor="green"/>
      <mx:Panel id="pan3" name="three" width="100%" height="100%" title="Number 3" backgroundAlpha="0.4"  backgroundColor="black"/>
      </mx:ViewStack>
      </mx:WindowedApplication>
