5 Replies Latest reply on Oct 28, 2009 6:00 AM by Matt Le Fevre
    Populating Datagrid with PHP Array
    virkof25 Level 1
      Hi everyone,
      I have been searching on the web and I don't seem to find anything in how to populate the column of a datagrid with an Array.
      I have a DB call users and I need to get the names stored on the database and display it on a datagrid.
      Any ideas??
        • 1. Re: Populating Datagrid with PHP Array
          Matt Le Fevre Level 4
          PHP and Flex communicate by XML
          you'll need the PHP page to print XML, and the Flex to access it using a HTTPService.
          quick example in lax code,
          have the PHP script setup to print something like;
          print "<users>"
          while (there are users)
          print "<username>".$username."</username>";
          print "</users>"
          then, access it using a HTTP service in flex, with the url of the service directed to the PHP file
          set a result Event in the HTTP service to call a function...
          then in the function have something like;
          datagrid.dataprovider = event.result.users;
          set the LabelField property of the datagrid to "username"
          and your datagrid would populate with all the user names
          • 2. Re: Populating Datagrid with PHP Array
            virkof25 Level 1
            Thank you! I will give it a try.
            • 3. Re: Populating Datagrid with PHP Array
              Here's a quick example using actual code which might be easier to understand;
              Flex code:
              <mx:HTTPService id="getStuff"  showBusyCursor="true" result="sortStuff(event)" method="POST"  url="http://localhost/stuff.php" useProxy="false"/>
              private function sortStuff(evt:ResultEvent):void
                   datagrid1.dataprovider = evt.result.stuff;
                   datagrid1.labelField = "thing";
              PHP code:
              <?php
                  $i = 0
                  while (i < 10)
                      print "<stuff><thing>This is Row number ".$i."</thing></stuff>";
                      $i++;
              • 4. Re: Populating Datagrid with PHP Array
                virkof25 Level 1
                Thank you soo much for replying!
                Just one more question. I am reading those names from a DB. Shouldn't be the PHP file something like this?
                <code>
                $slq = "SELECT user_name FROM tbl_staff";
                $nameresult = mysql_query( $sql,$conn );
                while ($row=mysql_fetch_assoc($nameresult) )
                print "$nameresult";
                mysql_free_result( $nameresult );
                </code>
                • 5. Re: Populating Datagrid with PHP Array
                  <code>
                  </code>
                  it'll have to be something like:
                  print "<usernames>";
                  while (whatever)
                       print "<name>".$nameresult."</name>";
                  print "</usernames>";
                  each name needs to be stored in a seperate 'name' node.
                  then set the datagrid dataprovider to evt.result.code
                  set the datagrid labelField to "name"
                  the above stores it in XML format, which is what Flex can read.
