1 Reply Latest reply on Oct 27, 2009 2:16 PM by Peter deHaan
    How to combine XMLListCollections
    Handycam Level 1
      I have 5 components.  Each contains an XMLListCollection bound to a list that people can add stuff to (from a different list/XLC).
      The adding is working, since if I trace the component I get results:
      private function testBtn(event:MouseEvent):void {
           for each (var x:XML in step1.itemChosenColl){
      Where step1 is one of the components and itemChosenCollection is the list's DP.
      It traces the ln1 attribute of each item in the collection, as expected.
      Now I'd like a new collection of all the other collections, and pass this to another "final" component.  This component has a public XLC variable bound to a datagrid.  But this fails:
      recipe.completeIngredients = step1.itemChosenColl + step2.itemChosenColl;
      Saying I cannot coerce into an XLC.  So how is this done?
        • 1. Re: How to combine XMLListCollections
          Peter deHaan Level 4
          @Steve Lombardi,
          Try something like this. The XMLListCollection (and presumably other IList implementers) have an addAll() method, where you can specify the two collections to combine:
                  <s:Button click="button1_clickHandler(event);" />
                      protected function button1_clickHandler(evt:MouseEvent):void {
                  <s:XMLListCollection id="xmlListColl1">
                      <fx:XMLList xmlns="">
                          <item label="1. One" />
                          <item label="1. Two" />
                          <item label="1. Three" />
                          <item label="1. Four" />
                          <item label="1. Five" />
                  <s:XMLListCollection id="xmlListColl2">
                          <item label="2. Six" />
                          <item label="2. Seven" />
                          <item label="2. Eight" />
                          <item label="2. Nine" />
              <s:List id="lst"
                      left="20" top="20" />
