• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Too Many Slides
New Here ,
Oct 27, 2009 Oct 27, 2009
It's been a while since I used Captivate, but when i had the older version I was able to simulate the application screen by screen and each screen was a slide.  Now I've been "upgraded" to Captivate 3 and I now have several slides for each screen.  Using the tab key, the space bar or mouse to move from one field to another creates a new slide.  What can I do to prevent this & why is this a problem in an upgrade!  Any help is much appreciated.
TOPICS
Recording
Views
850
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
I'm not sure what the issue is here. You don't like the fact a screen is captured with each mouse click?
You always have the option of configuring Manual mode. In that mode Captivate will automatically capture the first slide, but every one after that you are on your own and must press the Print Screen key (or whatever key you assigned) to coax a capture.
Further note that even if automatically recording slides you are able to press the Print Screen key at any time to coax Captivate into capturing the screen.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for the reply, I guess I didn't do a good job explaining what the issue is.  Captivate 3 creates a new slide whenever I use the tab key or the space bar.  I am trying to create a demo of an online form, so I'm recording keystrokes, however, everytime I type into a form field captivate creates a separate slide for each word that I type when I use the space bar or when I tab to move to a different field.  This did not use to happen before, Captivate used to capture the entire screen even when I tab to a different field or type a long sentence in a field.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 28, 2009 Oct 28, 2009
Hello,
Perhaps my memory is getting used and fuzzy, but it tells me that using automatic recording always resulted in slide captures whenever something changed during capture such as clicking, pressing a key, typing in text. You do not have to worry a lot about the memory taken up, because I've the feeling that only changed things are stored (Rick? Hope I'm right).
Rick gave you almost the same suggestions as I did (apparently we were typing at the same time, on different continents). Did you preview the movie and is the result not what you want? You can change from automatic recording to manual recording and press PrintScreen when you want a capture to be made. Since you are capturing in demonstration mode, all those slides are normally captured because on each slide (default settings) you will get the proper Text Caption added.
It is perhaps a terminology problem, but I'm a bit bewildered by your sentence 'capture the entire screen'. What do you mean? Is CP3 not capturing the entire screen? I could be wrong but seem to remember that CP3 did not have any automatic panning (new feature in CP4).
Hope you can explain your concerns about 'too many slides', please try to view the result
Lilybiri
Votes
Translate
Translate
Report
Report
Community Expert ,
Hello,
This is the way CP has always worked (use it since CP1). Perhaps in the older version you were using the manual capturing, which can still be used. Then you will control each slide to be captured by using PrintScreen on your keyboard? And now your capture has been made automatically, each time something changes on the screen a new slide will be created. Did you try to preview your movie? Was the result not what you wanted? If so, please explain somehow more in detail what you want.
Lilybiri
LOL, Rick, we were typing (pretty much the same message) at the same time. Telepathy?
Votes
Translate
Translate
Report
Report
Guest
Oct 29, 2009 Oct 29, 2009
LATEST
Hi Mefua,
as per your problem:
"Using the tab key, the space bar or mouse to move from one field to another creates a new slide.  What can I do to prevent this & why is this a problem in an upgrade!  Any help is much appreciated."
According to my understanding you do not want a new slide to be generated on keypresses. Launch the preferences dialog(Edit -> preferences), go to Recording and uncheck the "Record keystrokes" check box.
Alternatively, you could also use Manual mode, where in Captivate generates slides on your will.
-Manish
Votes
Translate
Translate
Report
Report
Resources
Help resources
