0 Replies Latest reply on Oct 27, 2009 12:33 PM by CoreyRLucier
    [svn:fx-trunk] 11189: Adding better support for deferred instantiation and states.
    CoreyRLucier Adobe Employee
      Revision: 11189
      Author:   clucier@adobe.com
      Date:     2009-10-27 12:33:04 -0700 (Tue, 27 Oct 2009)
      Log Message:
      Adding better support for deferred instantiation and states. State overrides can now correctly override targets that are instantiated after a state change.  Moving the commitment of the initial state to earlier (during commit properties), this should avoid the secondary layout pass that used to occur after applicationComplete.  Removed creationComplete handler in UIComponent as it is no longer needed.  Fixing an issue in Group that was causing blendMode to be stuck as 'layered' when setting alpha to 0 then resetting it to a non zero value.
      QE notes: None
      Doc notes: None
      Bugs: SDK-23105, SDK-23470, SDK-23790
      Reviewer: Deepa, Glenn
      Tests run: Full Cyclone, Checkin
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23105
          http://bugs.adobe.com/jira/browse/SDK-23470
          http://bugs.adobe.com/jira/browse/SDK-23790
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/AddChild.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/AddItems.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/OverrideBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/RemoveChild.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetEventHandler.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetProperty.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetStyle.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
