2 Replies Latest reply on Oct 28, 2009 7:27 AM by Mike6679
    Custom Button Class wordWrap
    Mike6679
      Anyone know how to make text wrap for a custom  Button Class? I have tried everything (as you can see below) ! I even tried the Flexlib CanvasButton class, but not really sure how to apply that to a custom Class. BTW these buttons are inside a TileList if that makes any difference....I really like Flex but sometimes its these really simple things that you SHOULD be able to do easily that just drive me NUTS!
      thanks in advance!!
      -Mike
      package action.button
          import flash.display.*;
          import flash.events.*;
          import mx.controls.Button;
          import mx.controls.listClasses.BaseListData;
          import mx.controls.listClasses.ListData;
          import action.button.NoTruncationUITextField;
          import mx.core.UITextField;
          import flexlib.controls.CanvasButton;
          public class ButtonCatSearch extends Button
              private var _baseListData:BaseListData;
              private var _listData:ListData;
              private var _label:String="";
              public function ButtonCatSearch()
                  super();
                  //make the cursor always behave like it's over a button
                  mouseChildren=false;
                  buttonMode=true;
                  useHandCursor=true;
                  height= 150;
                  width= 20;
                  setStyle("paddingLeft", 50);
                  setStyle("paddingRight", 50);
                  setStyle("paddingTop", 50);
                  setStyle("paddingBottom", 50);
                  setStyle("horizontalGap",100);
                  setStyle("wordWrap",true);
                  //wordWrap=true;
                  addEventListener(MouseEvent.MOUSE_DOWN,onButtonClick);
              public function onButtonClick(e:Event):void
                  _label = e.target.label;
              //to allow word wrap
              //for Button
              override protected function createChildren():void
                  // Create a UITextField to display the label.
                  if (!textField)
                      textField = new UITextField();
                      textField.styleName = this;
                      addChild(DisplayObject(textField));
                  super.createChildren();
                  textField.multiline = true;
                  textField.wordWrap = true;
              override public function get listData():BaseListData
                  return _baseListData;
               *  @private
              override public function set listData(value:BaseListData):void
                  super.listData = value;
                  _baseListData = value;
                  _listData = _baseListData as ListData;
              override public function set data(value:Object):void
                  /*if (_listData) {
                      if (_listData.icon) {
                          this.setStyle('icon', _listData.icon);
                  super.data=value;
                  setStyle("wordWrap", true);
              override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                  super.updateDisplayList(unscaledWidth, unscaledHeight);
                  this.textField.multiline = true;
                  this.textField.wordWrap = true;
                  //data.@price <= 0) ? NEGATIVE_COLOR : POSITIVE_COLOR);
        • 1. Re: Custom Button Class wordWrap
          paul.williams Level 4
          You'll need to override measure() to get the correct behaviour. By default the Button sets its width from the TextField child. What you want is for the width of the TextField to be limited by the width of the Button, and the height of the Button to vary depending on the measured height of the TextField.
          I've had a quick go at this below, but it'll probably need more work. I used Alex Harui's multi-line radio button example as a starting point:
          http://blogs.adobe.com/aharui/2007/04/multiline_buttons.html
          package
              import flash.display.DisplayObject;
              import mx.core.IUITextField;
              public class WordWrapButton extends Button
                  protected override function createChildren() : void
                      if ( !textField )
                          textField = IUITextField( createInFontContext( UITextFieldNoTruncation ) );
                          addChild( DisplayObject( textField ) );
                  override protected function measure() : void
                      if ( isNaN( explicitWidth ) == false )
                          textField.text = label;
                          textField.width =
                              explicitWidth -
                              getStyle( "paddingLeft" ) -
                              getStyle( "paddingRight" );
                          measuredHeight =
                              textField.getExplicitOrMeasuredHeight() +
                              getStyle( "paddingTop" ) +
                              getStyle( "paddingBottom" );
                      else
                          super.measure();
                      unscaledWidth : Number, unscaledHeight : Number ) : void
                      super.updateDisplayList( unscaledWidth, unscaledHeight );
                      textField.setActualSize(
                          textField.width,
                          textField.getExplicitOrMeasuredHeight() );
                      textField.move( textField.x, getStyle( "paddingTop" ) );
          package
              import flash.text.TextFormat;
              import flash.text.TextFormatAlign;
              public class UITextFieldNoTruncation extends UITextField
                  public override function truncateToFit( truncationIndicator : String = null ) : Boolean
                      return false;
          <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml"
              layout="vertical"
              xmlns:local="*">
              <local:WordWrapButton
                  width="50"
                  label="A very long label that I would like the button to wrap"/>
                  width="100"
                  width="200"
                  width="300"
                  width="400"
          </mx:Application>
          • 2. Re: Custom Button Class wordWrap
            Mike6679 Level 1
            Thanks Paul!  That did the trick. Like you said , I just had to tweak it a bit....
                            textField.width,
                       // I added this code here to nudge the text box up a bit so the textfld is centered
                        if(textField.height > TEXTFLD_MIN_HEIGHT /* in my case 18 for one line 30 for multiline*/
                            var spaceTopBottom:Number = BUTTON_HEIGHT - textField.height;
                            textField.move( textField.x, textField.y-6 );
                       //else if one line it will be centered on its own........
