1 Reply Latest reply on Oct 28, 2009 6:24 AM by Thomas B. Nielsen
    [CS3][JS] Apply XML tag for selected text
    kumar1981
      Hi
        I need to apply XML tag to selected text in a tagged content.The XML tag is already applied for paragraph.I need to apply XML Tag for selected text in a paragraph.
      I have used following code, it applies tag for entire paragraph,not a selected text in a paragraph.
      app.selection[0].associatedXMLElements[0].markupTag=myDoc.xmlTags.item("italic");
      Please suggest me.
      Regards
      kumar
        • 1. Re: [CS3][JS] Apply XML tag for selected text
          Thomas B. Nielsen Level 3
          The example script, markup.jsx
          //Markup.jsx
          //An InDesign CS4 JavaScript
          //Shows how to use the markup method.
          main();
          function main(){
              mySetup();
              mySnippet();
              myTeardown();
          function mySetup(){
              var myDocument = app.documents.add();
              var myPage = app.activeWindow.activePage;
              var myRootXMLElement = myDocument.xmlElements.item(0);
              var myXMLTag = myDocument.xmlTags.add("xml_element");
              var myXMLElementA = myRootXMLElement.xmlElements.add(myXMLTag);
              myXMLElementA.contents = "This is a paragraph in an XML story.";
              var myTextFrame = myPage.textFrames.add({geometricBounds:myGetBounds(myDocument, myPage)});
              myTextFrame.contents = "This is the first paragraph in a text frame.\rThis is the second paragraph in a text frame.\rThis is the third paragraph in a text frame.\rThis is the fourth paragraph in a text frame.\r";
          function mySnippet(){
              //<fragment>
              var myDocument = app.documents.item(0);
              var myPage = myDocument.pages.item(0);
              myDocument.xmlElements.item(0).xmlElements.item(0).markup(myPage.textFrames.item(0));
              //</fragment>
          function myTeardown(){
          function myGetBounds(myDocument, myPage){
              var myPageWidth = myDocument.documentPreferences.pageWidth;
              var myPageHeight = myDocument.documentPreferences.pageHeight
              if(myPage.side == PageSideOptions.leftHand){
                  var myX2 = myPage.marginPreferences.left;
                  var myX1 = myPage.marginPreferences.right;
              else{
                  var myX1 = myPage.marginPreferences.left;
                  var myX2 = myPage.marginPreferences.right;
              var myY1 = myPage.marginPreferences.top;
              var myX2 = myPageWidth - myX2;
              var myY2 = myPageHeight - myPage.marginPreferences.bottom;
              return [myY1, myX1, myY2, myX2];
          I think you can use the markup function on the selected item (Text Object have a markup method)
          Thomas B. Nielsen
          http://www.lund-co.dk
