6 Replies Latest reply on Oct 30, 2009 6:42 AM by djkhalif
    Cfselect populating cfinput readonly?
    djkhalif Level 1
      Good morning all,
      I have a form that I want to use cfselect to drop employee FN and LN from the drop down username into a readonly cfinput. Do I need to bind or what is the best method to accomplish this? I also want to open a new form (popup) to select from there to other fields in the original form. I know the second part is javascript but can anybody point me in the right direction?
      Thanks in advance,
      djkhalif
        • 1. Re: Cfselect populating cfinput readonly?
          Dan Bracuk Level 5
          <input> has a disabled attribute to make it read only.  To change the value based on another form field, you'll have to use javascript.
          • 2. Re: Cfselect populating cfinput readonly?
            BKBK Adobe Community Professional & MVP
            You may use bind in both cases. Here's an example to start you up
            <div>
            <strong>Form 1</strong>
            <cfform id="form1" name="form1">
            <select name="firstName">
            <option value="">Select first name</option>
            <option value="01">Alf</option>
            <option value="02">Bill</option>
            </select>
            <br>
            First Name: <cfinput type="text" name="fn" bind="{firstName.text}" readonly="true">
            <br>
            City: <cfinput type="text" name="city1" bind="{form2:city2}">
            <br>
            Country: <cfinput type="text" name="country1" bind="{form2:country2}">
            </cfform>
            </div>
            <div>
            <strong>Form 2</strong>
            <cfform id="form2" name="form2">
            <select name="city2">
            <option value="">Select city</option>
            <option value="Amsterdam">Amsterdam</option>
            <option value="Bratislava">Bratislava</option>
            </select>
            <br>
            Country: <cfinput type="text" name="country2">
            </cfform>
            </div>
            • 3. Re: Cfselect populating cfinput readonly?
              djkhalif Level 1
              BKBK,
              That did it!
              djkhalif
              • 4. Re: Cfselect populating cfinput readonly?
                djkhalif Level 1
                BKBK,
                I do see that in a form the format="flash" does not work bind. Nor can I use values from two columns with <cfselect query="tlkp_Inspector" value="firstName"></cfselect>. For value, value="firstName lastName"
                • 5. Re: Cfselect populating cfinput readonly?
                  Bind works for Flash, too. But, first, you have to remove the HTML tags.
                  <cfform id="form1" name="form1" format="flash">
                  <cfselect label="First Name" name="firstName" width="200">
                  </cfselect>
                  <cfinput label="FN" type="text" name="fn" bind="{firstName.text}" readonly="true" width="200">
                  </cfform>
                  • 6. Re: Cfselect populating cfinput readonly?
                    djkhalif Level 1
                    BKBK,
                    I made a change that did not work. I corrected it, now the code works fine.
                    <cfform format="flash" id="FI" name="FI" action="../ActionPages/finalinspectionaction.cfm" method="post" width="550" height="600">
                    <cfinput type="datefield" value="#dateformat(Now(), 'mm/dd/yyyy')#" name="inspectionDate" width="120" label="Date of Inspection">
                    <cfinput type="text" name="WorkOrder" required="yes" message="Oops! You must enter the Work Order Number" width="120" label="Work Order">
                    <cfselect name="inspectedById" query="inspectBy" value="FullName" display="inspBy" label="Select your name as the Inspector" width="60" required="yes">
                    </cfselect>
                    <cfinput name="InspectedByName" type="text" width="120" readonly="true" label="Inspected By" bind="{inspectedById.text}">
                    <cfinput name="totalInspected" type="text" width="60" readonly="true" label="Total Inspected">
                    <cfinput name="totaldefective" type="text" width="60" readonly="true" label="Total Defective:">
                    <cfinput name="totaldefects" type="text" width="60" readonly="True" label="Total Defects:">
                    <cftextarea name="notes" cols="30" rows="5" label="Comments / Notes"></cftextarea>
                    <cfinput type="submit" name="submit" value="Submit">
                    <cfinput type="reset" name="clear" value="Clear Form">
                    </cfform>
