7 Replies Latest reply on Oct 29, 2009 2:23 AM by JLAMBERT76
    Trouble selecting lines inside a clipping mask
      I don't know if anyone else has had this problem but i've just upgraded to CS4 and am having a few problems in illustrator.
      I have an illustration of a shirt where the collar and cuffs are illustrated by lots of lines which are sat inside a clipping mask to illustrate the ribbing.
      I used to be able to select each of these lines individually when using CS3 but now that I'm using CS4 it won't let me do this, it literally won't select the lines.  I wondered if something had changed with regards clipping paths in the upgrade as if i take the same file back into CS3 it works perfectly?
      If anyone else has had a similar problem and found a solution i'd really appreciate any help you could give me!!
