4 Replies Latest reply on Oct 28, 2009 12:23 PM by frist44
    Facebox in Flash
      I would like to create an AJAX style pop up to present photos from a flash movie. I found a tutorial, but it didn't work for me. I'm trying to trigger it off the gerURL function of a button, but nothing popups. I have verified that a simple link in <a> from the html page the flash movie is on works fine, so it's just the call from flash itself.
      Any suggestions?
        • 1. Re: Facebox in Flash
          I have no familiarity with the type of interface you are trying to present (by name), but here are some possible solutions:
          1)  If the html code is able to produce the desired result, then you could use External Interface to have Flash call the html page's function.  Here's a link regarding that for AS2 and As3.
          2) If the popup is like any other popup, then here's a link that discusses a variety of ways to open content in both AS2 and AS3:
          • 2. Re: Facebox in Flash
            frist44 Level 1
            I went with lightbox because there seemed to be more material about it. I tried this:
            I used the javascript function in the my html:
            function GroupDelegate(id) {
               var objLink = document.getElementById(id);
            And then called it from the flash using this:
            However, my whole screen turns white and i don't see anything. I added a normal <a> link to my html and the light box works fine, so I'm thinking it has something to do with the flash.
            any thoughts?
            • 3. Re: Facebox in Flash
              I suggest looking into the first suggestion I offered, where you will use ExternalInterface to have Flash call that javascript function.
              • 4. Re: Facebox in Flash
                frist44 Level 1
                I get the same behavior: an all white screen as though something is popping up covering the movie.
                import flash.external.*;
                //Next Button click even
                btnPics.onRelease = function() {
                    //getURL("javascript:window.open('somePage.html','thewin','height=400,width=600,toolbar=n o,scrollbars=no')");
