4 Replies Latest reply on Aug 4, 2012 10:00 AM by micostar
    Stopping from command line help
    Sorack01
      Hi all.
      I am running fmlecmd.exe to start from a batch file. Works great. But I am following the instructions on getting a batch file to stop the application.
      It's not working.
      Instructions:
      "When the session is streaming to a server, use the format fms_URL+stream_name for fmle_UID. For example, to stop an encoding session that is running on the server fms.myserver.com with the application named live, and the stream named livestream, you would enter the following: FMLEcmd /s rtmp://fms.myserver.com/live+livestream
      Note: When using the /s parameter, the stream_name portion of fmle_UID cannot contain a plus sign (+), because + is used as a delimiter in fmle_UID."
      I can't find where my 'application' name is to enter into the path. Here is what my stop.bat file looks like:
      "C:\Program Files\Adobe\Flash Media Live Encoder 3\FMLECmd.exe" /s rtmp://p.ep9729.i.akamaientrypoint.net/EntryPoint/live/WNEP-FLASH-LIVE-1@9729
      Here is the only info I can find: (no 'application' name, so the above stop.bat file has /live/ in the path)
      Stream to Flash Media Server :-
      FMS URL    : rtmp://p.ep9729.i.akamaientrypoint.net/EntryPoint
      Backup URL  : rtmp://b.ep9729.i.akamaientrypoint.net/EntryPoint
      Stream Name : WNEP-FLASH-LIVE-1@9729
      Where do I find the application name to enter into the path?
      Thank you for any help in advance.
      Chris
        • 1. Re: Stopping from command line help
          Vineet Mahajan Level 1
          Chris,
          Your FMLE UID is wrong.
          For your FMLE session, the fmle uid should be "rtmp://p.ep9729.i.akamaientrypoint.net/EntryPoint+WNEP-FLASH-LIVE-1@9729"
          Hence the command you give to stop the FMLE session should be :-
          "C:\Program Files\Adobe\Flash Media Live Encoder 3\FMLECmd.exe" /s rtmp://p.ep9729.i.akamaientrypoint.net/EntryPoint+WNEP-FLASH-LIVE-1@9729
          Please try this and let us know if you face any more problems.
          • 2. Re: Stopping from command line help
            Sorack01 Level 1
            Vineet,
            Perfect, it worked.
            Thank you very much!
            Chris
            • 3. Re: Stopping from command line help
              gstrudler
              I am having problems stopping from a batch file as well. I can start from a  batch file just fine, but the batch file to stop just doesn't work. The strange thing is that I can open a command line window and enter the exact same text and get the encode to stop (so I know I'm entering the UID right), but as soon as I put it into the batch file it doesn't work. Ideas? FMLE is streaming multiple files at the same time, but no DVR and no archiving.
              FMLE 3.2 on Win XP (SP3).
              • 4. Re: Stopping from command line help
                micostar
                I am experiencing the same issue above.
                I can start, stop, and unregister streams from the command line with no problems. If I then check FMLEcmd /dvrstate I get the correct results.
                However, if I put start, stop, and unregister in a BAT file, the session is not unregistered and I have to either delete the fmesessions.dat file to clean up the error OR I have to rerun the same uid, start, stop, and unregister it from command line.
                Just to be extra clear - the session can be stopped from the BAT file. The person above might think that just because an uid appears in the registry that the stream is running and that is not the case.
                I am running all of my BAT files as Administrator so I don't think permissions is the issue. This seems like a bug, but I dont know the back end rules about how fmesessions.dat and OsLaunch.dat work together. It seems like the OsLaunch is correct, but fmesessions is not. FMLEcmd is reading from fmesessions.
                Any thoughts on how to successfully unregister a uid from a BAT file?
