5 Replies Latest reply on Jun 15, 2008 9:10 AM by Newsgroup_User
    Developing PHP locally
    gordonwd
      I'm going to be developing a PHP-based site, but don't need to set up any live database connections in DW. However, I'd like to test my code locally, so I will be installing the Apache web server and PHP extensions to be accessible via " http://localhost/..." etc.
      To do this, I assume that I should define my site so it is based in a subdirectory under the web server's directory tree. But is there a way to use DW's browser preview feature and have it use a local web server connection instead of accessing the page by a direct file reference? That is, preview " http://localhost/myproj/index.php" instead of "C:\something\myproj\index.php", which is not at all the same thing?
      Any other tips for local PHP-based development?
        • 1. Re: Developing PHP locally
          Level 7
          > That is, preview
          when you enter testing server info into a Site Definition, dw uses the "http
          prefix" entered as the beginning of the url to use when F12 is pressed.
          in other words- IF you define a testing server, an F12 will bring up
          http://localhost/whatever/thatpage.php
          Alan
          Adobe Community Expert, dreamweaver
          http://www.adobe.com/communities/experts/
          • 2. Re: Developing PHP locally
            gordonwd Level 1
            Thanks, Alan. I had read something about the testing server, but it was not clear exactly how all the pieces fit together.
            • 3. Re: Developing PHP locally
              Level 7
              Yes- if you declare a testing server in the site definition, dreamweaver
              changes the way it does F12 Preview in Browser.
              Instead of sending the code to the browser, dw using the info entered about
              the Testing server to send the relevant files to the proper location
              (either a locally installed testing server folder or even a remote ftp
              location, you can use your remote host or a subdomain of the site as the
              testing server. There's a lag while the files get transferred though)
              then opens the browser with the "http prefix" of where the testing server
              site can be seen.
              Usually we get asked this question in the other direction; people who don't
              need a testing server for their Site definition fill in information for it
              mistakenly. Then can't understand why they get a 404 error message when they
              hit F12 to preview their plain html pages.
              Install the server and PHP and MySQL, get that part working.
              Then define the site in dw, and fill in the Testing Server information.
              Tip: If you know what most of the terms mean, the Advanced tab in the New
              Site Dialog box is easier to fill out than the "wizard" step by step
              version.
              Alan
              • 4. Re: Developing PHP locally
                gordonwd Level 1
                So is it OK to actually have my working DW folders be the same ones that my local web server uses? In other words, no transfer to the testing server would be required because the files would already be there. This would work out well for the way I do my work, but would it confuse DW at all?
                It sounds from your reply like DW wants to transfer the files from my working site directories to another directory on my PC where the web server operates. Or maybe I just have to try all of this and see what happens...
                • 5. Re: Developing PHP locally
                  Level 7
                  Yes, you can do it that way.
                  Or you can have the Local Site Folder and Testing Server Site Folder in
                  different locations, then dw will take a second to transfer the current work
                  file to the testing server location then open the browser.
                  The main thing is to get the Site Definition info correct for what you want
                  to set up.
                  Alan
