2 Replies Latest reply on Jul 14, 2008 1:43 PM by Hamshmam
    Explanation of how multiple applications/windows work
    Hamshmam Level 1
      Hi all,
      I want to create an application that has a login screen (currently a WindowedApplication), which disappears upon succesful login and then goes to a Window with a side panel and a main panel (split using an HDividedBox).
      The main panel in the HDividedBox is going to have a lot of logic, so I was thinking about adding an ApplicationControlBar, but is it true that it won't dock to the top since it's parent container is a HDividedBox (and not an Application)?
      I was thinking perhaps I could make the "main window" a WindowedApplication so that I could just have the ApplicationControlBar dock to the top of the whole thing, and allow it to control the entire HDividedBox as is. I was wondering if this is the best way to approach such a layout, because I'm still confused as to whether or not I can have multiple Applications within the same Flex Application, if I should use them, and if not, how to go around them since I need to share data between components. Thanks so much!
