4 Replies Latest reply on Oct 28, 2009 6:03 PM by icecream841
    CS4 Reinstalation
    icecream841
      Hi, I'm planning on uninstalling then reinstalling premiere pro but one of the things I wasn't to sure about is weather or not it will still have the activation code entered or will I need to re enter it.
      And thats it so it should be pretty easy
      Alex,
        • 1. Re: CS4 Reinstalation
          SFL46 Level 3
          Make sure you deactivate the CS4 suite before you de-install.  You will need to re-activate once you complete re-installing.  Buit if you don't de-activate, you will be told that a version is already active and that you must de-activate first--but of course, you no longer have the installation.  Do it first!
          • 2. Re: CS4 Reinstalation
            icecream841 Level 1
            How do i go about deactivating it?
            Where is the program or place that allows me to do so it said something about a third party program, but I haven't been able to locate it...
            And thank you very much for your help
            • 3. Re: CS4 Reinstalation
              SFL46 Level 3
              In the help menu drop-down, you'lll find the activate and deactivation tasks.  If you installed one of the Adobe CS4 suites--you usually only need to deactivate one program in the suite--the rest will also be deactivated.  You might want to check.  If the program is deactivated, the deactivate fuction will be greyed out.
              I'd like to make a suggestion to you.  Your question implies that you need to spend some time with the manual.
              • 4. Re: CS4 Reinstalation
                icecream841 Level 1
                Thank you again,
                I probably should spend a little more time in the manual....
