Revision: 11247
Author: klin@adobe.com
Date: 2009-10-28 14:59:11 -0700 (Wed, 28 Oct 2009)
Log Message:
Fix for https://bugs.adobe.com/jira/browse/SDK-23184.
Updated a bunch of Style metadata ASDocs to describe different defaults between the Halo and Spark themes. Also, fixed a few typos along the way.
defaults.css - rearranged a few styles to be in alphabetical order
Button.as - removed extra emphasizedSkin style metadata
Panel.as - added spark theme to borderAlpha metadata
QE notes: None
Doc notes: None
Bugs: SDK-23184
Reviewer: Glenn
Tests run: checkintests
Is noteworthy for integration: No
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-23184
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/defaults.css
flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Panel.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DataGrid.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/LinkBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/LinkButton.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/List.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ProgressBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Tree.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/colorPickerClasses/SwatchPanel.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileListItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/menuClasses/MenuItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/TreeItemRenderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManagerProxy.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PopUpMenuIcon.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/BorderStyles.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/FocusStyles.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/GapStyles.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/PaddingStyles.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/SkinStyles.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/TextStyles.as
flex/sdk/trunk/frameworks/projects/halo/defaults.css
flex/sdk/trunk/frameworks/projects/spark/src/fl/video/NCManagerDynamicStream.as
flex/sdk/trunk/frameworks/projects/spark/src/fl/video/NCManagerNative.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBarButton.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransformInstance.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/TileLayout.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/StrokedElement.as
