0 Replies Latest reply on Oct 29, 2009 3:13 AM by andrew@ivimeds
    generated webservices give null result in Flex 3
    andrew@ivimeds
      Hi there,  I have a web service on my localhost. Calling this from a PHP page works fine and it returns the expected results. (I pass 2 values and it returns a different string depending on the values passed).
      However, in Flex 3, I have generated the webservice proxy classes using the "Data" | "Manage Web Services" dialog.  I am consuming these services using the following code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
           <mx:Button click="clickHandler(event)"/>
           <mx:Script>
                <![CDATA[
                     import generated.webservices.*;
                     import mx.controls.Alert;
                     import mx.rpc.events.FaultEvent;
                     public var _ws:SalesService = new SalesService();
                     private function clickHandler(_e:MouseEvent):void
                          _ws.addonsaleEventListener(resultHandler);
                          _ws.addSalesServiceFaultEventListener(faultHandler);
                          _ws.onsale(10,90);
                     public function resultHandler(_e:OnsaleResultEvent):void
                          if(_e.result == null)
                               Alert.show("result is: null");
                          else
                               Alert.show("result is: "+_e.result);
                     public function faultHandler(_e:FaultEvent):void
                          Alert.show(_e.message.toString());
           </mx:Script>
      </mx:Application>
      The "resultHandler" method is called and the "faultHandler" method is not called, which suggests a result is returned, but _e.result is null in the "resultHandler" method.
      Can anyone see if I am missing something in the actionscript?
      Andrew.
      p.s.
      I can post the generated proxy classes, or even the wsdl for the webservice if it helps.
      A.
