3 Replies Latest reply on Oct 29, 2009 5:58 PM by Darrell Loverin
    ConfigurationInfo argcount
    Marvin Velo
      What is the meaning of negative values on flex2.compiler.config.ConfigurationInfo.argcount ?
      I saw it being assigned with -1 and -2 values.... I assume -1 is an array like... but what about -2?  Is there a -3, -4, -X that I should be aware also?
      VELO
        • 1. Re: ConfigurationInfo argcount
          Darrell Loverin Level 4
          If argcount equals -1 it means there is a list of items
             argcount equal -2 means a specific argcount has not been specified in the constructor. Later on the number of arguments is determined.
          There are no -3, -4, ... argcounts.
          • 2. Re: ConfigurationInfo argcount
            Marvin Velo Level 1
            Ok, about this -2 .... later when?  Is there anyway to retrieve this information?
            For instance:
                 public static ConfigurationInfo getRuntimeSharedLibraryPathInfo()
                      return new ConfigurationInfo()
                           public boolean allowMultiple()
                                return true;
                           public String[] getSoftPrerequisites()
                                return new String[] {"static-link-runtime-shared-libraries"};
                           public String getArgName(int argnum)
                                String argName = null;
                                if (argnum == 0)
                                     argName = "path-element";
                                else
                                     argnum = (argnum + 1) % 2;
                                     if (argnum == 0)
                                          argName = "rsl-url";
                                     else
                                          argName = "policy-file-url";
                                return argName;
                           public boolean doChecksum()
                                return false;
            The argcount is never defined here, I wonder is there is any way to interpolate this value.....
            VELO
            • 3. Re: ConfigurationInfo argcount
              See ConfigurationInfo.setSetterMethod. Set a breakpoint on the "argcount = -1;" line.
                 protected final void setSetterMethod( Method setter )
                      Class[] pt = setter.getParameterTypes();
                      assert ( pt.length >= 2 ) : ( "coding error: config setter must take at least 2 args!" );
                      this.setter = setter;
                      if (pt.length == 2)
                          Class c = pt[1];
                          if (ConfigurationBuffer.isSupportedListType( c ))
                              if (argcount == -2)
                                  argcount = -1;      // infinite list
                              argtypes = new Class[] {String.class};
                              return;
