3 Replies Latest reply on Nov 9, 2009 11:53 AM by holografer
    FLV image not sharp
      When outputting a FLV from Premiere Pro CS4 through the Export Settings, the video image of the FLV, when rendered through
      Media Encoder CS4, is not as sharp as the original video footage as seen in Premiere or Windows Media Player.  The aspect
      ratio (and size) has been maintained when setting up the parameters in the Export Settings. I usually use On2 VP6 as my
      codec but also tried Sorenson and got the same results.  My bandwidth setting is usually around 700 kpbs but jacking it up
      to 1,500 kpbs didn't help at all (which I didn't expect it to).  If I output the video from Premiere as an uncompressed AVI
      file and place the AVI file on the Flash timeline and produce the SWF file, the image is excellent.  It seems that the
      Media Encoder and/or codec are somehow causing this softening (defocusing) of the image.  Has anyone else experienced this?
        • 1. Re: FLV image not sharp
          Jim_Simon Level 8
          I haven't noticed a softening, but I wasn't getting the full image quality I wanted with .flv, so I switched to .f4v and I find the results better.
          • 2. Re: FLV image not sharp
            jpleong Level 1
            You may also want to check your graphics card settings. I had a soft-focus rendering problem once while using Ultra CS3 which I discovered was directly related to the Performance vs Quality settings in the ATi Catalyst Control Panel.
            • 3. FLV image not sharp
              holografer Level 1
              I have done a  comparison between Premiere CS3 and Premiere CS4 generation of a FLV file and the FLV file from CS3 is sharp as a tack whereas the FLV file from CS4 is not as sharp and is softened (blurred).  All perimeters were kept the same between both softwares.  I guess there's no one else who's ran across this situation?
