2 Replies Latest reply on Oct 30, 2009 6:58 AM by DennisTh
    addChild doesn't effect for some reason REFdn2065133102
    DennisTh
      In small test application I have the follow object… stack
      The “Main.mxml” loads the EntryClass.as -> “class EntryClass” (that doesn’t extends anything) -> “public static function Main()”.
      This EntryClass.Main() function is doing the follow:
            var mxmlApp:Application = Application(Application.application);
            var mainAppClass:MainAppClass=new MainAppClass();
            mxmlApp.addChild(mainAppClass);
      So the mainAppClass is loaded.
      Now the MainAppClass extends the UIComponent and in its constructor does this:
            var buttonFromMainClass:Button=new Button();
            buttonFromMainClass.x=20;buttonFromMainClass.y=20;buttonFromMainClass.label="hello world";
      to add it to stage I call
            addChild(buttonFromMainClass);
      and here is the problem! The button is not appeared on the stage, but using this code:
            Application(Application.application).addChild(buttonFromMainClass);
      the button is added to the stage and it is visible.
      Why the button is not added to the stage with the simple addChild? Where am I wrong?
      Something that might be help, in EntryClass.Main() if I create a button and add it with the mxmlApp.addChild, the button is added and appeared on the stage normally, so there is no problem with the use of mxmlApp.addChild.
      Best regards
      Dennis
