0 Replies Latest reply on Oct 29, 2009 8:23 AM by Paul Reilly
    [svn:fx-trunk] 11255: * Another batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 11255
      Author:   preilly@adobe.com
      Date:     2009-10-29 08:23:33 -0700 (Thu, 29 Oct 2009)
      Log Message:
      • Another batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-23354, SDK-22804, SDK-22995, SDK-23561, SDK-23466
      Reviewer: Corey
      Tests run: full cyclone
      Is noteworthy for integration: Yes, The CSS PropertyReference()
                                     function only allows document property
                                     references now.
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler_en.properties
          Added css.StyleDef.InvalidPropertyReference and
          css.StyleDef.PropertyReferenceRequiresDocument.
        modules/compiler/src/java/flex2/compiler/as3/managed/ManagedFirstPassEvaluator.java
          Modified evaluate(Context, FunctionDefinitionNode) to check that
          the param type is String for uid setters.  This fixes SDK-23354.
        modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          Modified transferDependencies() to filter out bogus ReferenceValue
          names that occur when imports are missing.  This fixes SDK-22804.
        modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          Modified processReference() to only allow PropertyReference() to
          reference document properties.  This fixes SDK-22995.
        modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
          Modified generateInstanceVariables() to generate a line number
          mapped position for the TypeExpressionNode.  This fixes SDK-23561.
        modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          Modified emitBindingsSetup macro to generate a not null check for
          the destination function when the type is Array.  This fixes
          SDK-23466.
        modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          Modified generateSourceFunctionArrayConversion() to do the
          equivalent of the ClassDefLib.vm change.
        modules/compiler/src/java/flex2/compiler/util/MultiName.java
          Added assert for localName's to ensure they don't have a dot in
          them.  This should help us catch problems like SDK-22804 closer to
          the source.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23354
          http://bugs.adobe.com/jira/browse/SDK-22804
          http://bugs.adobe.com/jira/browse/SDK-22995
          http://bugs.adobe.com/jira/browse/SDK-23561
          http://bugs.adobe.com/jira/browse/SDK-23466
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedFirstPassEvalu ator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MultiName.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
