1 Reply Latest reply on Oct 29, 2009 1:56 PM by kglad
    Adding variables together imported from xml?
    Matt_Quay_Design
      Hi Everyone,
      I have yet another problem that i cant seem to solve
      I have imported some info from an xml file into my movie. The info from this file is then displayed in dynamic text boxes. Three of these text boxes show a price which displays fine. However i need the contents of these text boxes to be added together in another dynamic text box called total. I need this total to update as the price fields change. I just cant figure it out.
      Here is my code which is placed at frame 1 of my movie:
      The last line of code is along the lines of how i think it should work, but i think its probably totally wrong
      stop();
      bar._visible = false;
      bar2._visible = false;
      bar3._visible = false;
      please_wait._visible = false;
      //Populate cart with default items from xml file//
      function CreateMenu(cart_xml){
      // start with the first item in the XML
      var items = cart_xml.firstChild.firstChild.childNodes; // menu -> menuitems -> child nodes array
      for (var i=0; i<items.length; i++) {
      // only continue if the type of this item is a squirrel
      if (items[i].attributes.type == "silver") {
      // create variables for our elements
      var componentlegs = items[i].firstChild; // same as items[i].childNodes[0]
      var colourlegs = items[i].childNodes[1]; // second child node
      var pricelegs = items[i].childNodes[2]; // second child node
      var componentbody = items[i].childNodes[3];
      var colourbody = items[i].childNodes[4];
      var pricebody = items[i].childNodes[5];
      var componentbezel = items[i].childNodes[6];
      var colourbezel = items[i].childNodes[7];
      var pricebezel = items[i].childNodes[8];
      // assign text using nodeValue to get the text
      legs_component.text = componentlegs.firstChild.nodeValue;
      legs_colour.text = colourlegs.firstChild.nodeValue;
      legs_price.text = pricelegs.firstChild.nodeValue;
      body_component.text = componentbody.firstChild.nodeValue;
      body_colour.text = colourbody.firstChild.nodeValue;
      body_price.text = pricebody.firstChild.nodeValue;
      bezel_component.text = componentbezel.firstChild.nodeValue;
      bezel_colour.text = colourbezel.firstChild.nodeValue;
      bezel_price.text = pricebezel.firstChild.nodeValue;
      // manage XML
      // create new XML object instance, remembering to ignore white space
      var cart_xml = new XML();
      cart_xml.ignoreWhite = true;
      // define an onLoad to create our location menu when the XML has successfully loaded.
      cart_xml.onLoad = function(success){
      if (success) CreateMenu(this);
      else trace("Error loading XML file"); // no success?  trace error (wont be seen on web)
      // load the xml file!
      cart_xml.load("cart.xml");
      total = (Number(pricelegs))+(Number(pricebody))+(Number(pricebezel));
      Thank you in advance for any replies to my dilemma!
      Cheers
      Matt
        • 1. Re: Adding variables together imported from xml?
          try:
          stop();
          total = (Number(pricelegs.firstChild.nodeValue))+(Number(pricebody.firstChild.nodeValue))+(Number (pricebezel.firstChild.nodeValue));
          // manage XML
