8 Replies Latest reply on Jan 16, 2012 6:14 AM by Neal G. Davies
    Unable to create / open file
    zolouchka77 Level 1
      hi
      i try to create pdf with Output Service API Quick Starts, i copy code in the file in
      Web service API so i call my output service.
      i have a modele ComdeDynamiq.xdp
      i have  a  xml file for merging : PurchaseOrder.xml
      i add to url service ?blob=base64
      but my method generatePdfOutput don't run at all : no file generate
      and in my file output.xml where i put data in generatepdfOutputResultDoc.BinaryData there is :
      <?xml version="1.0" encoding="UTF-8"?>
      <printResult>
      <status>2</status>
      <requestId>611e915ba</requestId>
      <context>7</context>
      <messages>
      <message>Unable to create / open file C:\creerPdf\Res.pdf.</message>
      </messages>
      <printSpec/>
      </printResult>
      i don't knom what doesn't run in my code?? i give it in attach files? is there somoene which could help me??
      thanks
      my code is below :
      using
      System;
      using
      System.IO;
      using
      System.Collections;
      using
      System.ComponentModel;
      using
      System.Data;
      using
      System.Configuration;
      using
      System.Web;
      using
      System.Web.Security;
      using
      System.ServiceModel;
      using
      WebReference;
      <summary>
      Summary description for outPut
      </summary>
      public
      class TestOutPut
      public TestOutPut()
      // TODO: Add constructor logic here
      public void Essai()
      try
      // Appel du service output
      OutputServiceService outPutClient = new OutputServiceService();
      outPutClient.Url +=
      "?blob=base64";
      outPutClient.Credentials =
      new System.Net.NetworkCredential("administrator", "password");
      //creation d'un blob pour stocker les données du fichier
      BLOB inData = new BLOB();
      //reference du fichier xml à merger avec le modèle :
      String inPutFile = @"C:\\creerPdf\\PurchaseOrder.xml";
      FileStream fs = new FileStream(inPutFile, FileMode.Open);
      //on récupère la taille du flux du fichier et on crée un tableau de byte :
      int longueur = (int)fs.Length;
      Byte[] byteArray = new byte[longueur];
      //on remplit le tableau de byte avec le contenu du file stream :
      fs.Read(byteArray, 0, longueur);
      //on rempli le blob
      inData.binaryData = byteArray;
      //option de run time du pdf
      PDFOutputOptionsSpec pdfOptions = new PDFOutputOptionsSpec();
      pdfOptions.fileURI =
      "C:\\creerPdf\\Res.pdf";
      pdfOptions.lookAhead = 300;
      pdfOptions.generateManyFiles =
      false;
      pdfOptions.recordLevel = 1;
      //render options :
      RenderOptionsSpec renderOptions = new RenderOptionsSpec();
      renderOptions.cacheEnabled =
      true;
      //Create empty objects to pass as arguments
      //to the generatePDFOutput method
      //These objects are populated by the method
      BLOB generatePDFOutputMetaDataDoc = new BLOB();
      BLOB generatePDFOutputResultDoc = new BLOB();
      OutputResult outResult = new OutputResult();
      //On crée le doc pdf
      outPutClient.generatePDFOutput(
      TransformationFormat.PDF, "BonCmdeDynamiq.xdp", "C:\\creerPdf\\", pdfOptions, renderOptions, inData, out generatePDFOutputMetaDataDoc, out generatePDFOutputResultDoc, out outResult);
      //On ecrit les données vers output.pdf
      //on rempli un tableau de byte avec les données de sortie
      byte[] outByteArray = generatePDFOutputResultDoc.binaryData;
      //On crée un nouveau fichier pour stocker les données
      string FILE_NAME = "C:\\Adobe\\Output.xml";
      FileStream fs2 = new FileStream(FILE_NAME, FileMode.OpenOrCreate);
      //on ecrit le flux de données
      BinaryWriter w = new BinaryWriter(fs2);
      w.Write(outByteArray);
      w.Close();
      fs2.Close();
      fs.Close();
      catch(Exception ee)
      Console.WriteLine(ee.Message);
