1 Reply Latest reply on Nov 1, 2009 7:01 AM by levancho
    HTTP service command fails to load
    geo-bart Level 1
      Hello,
      I'm working on an application in which students uses data like the times of tides. It uses an rss-feed to fill up an Arraycollection, it cuts out the times and then put those times in a datagrid. I have a neat little table in a Tilewindow. Here's the code:
      <mx:TitleWindow
      xmlns:mx="http://www.adobe.com/2006/mxml
      title="
      Getijdentabel (Oostende)" xmlns:p="*" width="734" height="258" creationComplete="test.send()" verticalScrollPolicy="off" horizontalScrollPolicy="off" showCloseButton="true" close="PopUpManager.removePopUp(this);"
      <mx:Script>
      <![CDATA[
      import
      mx.collections.ArrayCollection;
      import
      mx.rpc.events.ResultEvent;
      import
      mx.managers.PopUpManager;
      import
      mx.controls.Text;
      import
      mx.controls.Alert;
      Bindable
      private var
      getijdenData:ArrayCollection;
      function resultHandler(event:ResultEvent):void
      getijdenData = test.lastResult.rss.channel.item;
      for(var
      i:uint = 0; i<getijdenData.length; i++){
      if(test.lastResult.rss.channel.item[i].description.slice(538,541) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(543,548);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(620,625);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(726,731);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(775,780);
      if(test.lastResult.rss.channel.item[i].description.slice(537,540) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(542,547);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(619,624);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(724,729);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(773,778);
      if(test.lastResult.rss.channel.item[i].description.slice(534,537) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(539,544);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(616,621);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(718,723);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(767,772);
      if(test.lastResult.rss.channel.item[i].description.slice(539,542) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(544,549);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(621,626);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(728,733);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(777,782);
      if(test.lastResult.rss.channel.item[i].description.slice(540,543) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(545,550);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(622,627);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(729,734);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(778,783);
      </mx:Script>
      <mx:HTTPService id="test" url="http://www.mumm.ac.be/NL/Models/Operational/Tides/rss.php?oostende" result="resultHandler(event)"
      <mx:Canvas width="100%" height="100%"
      <mx:DataGrid dataProvider="{getijdenData}" id="recente_getijden" color="0x323232" rowCount="7" editable="false" width="100%" height="163" enabled="true" verticalScrollPolicy="off"
      <mx:columns>
      <mx:DataGridColumn dataField="title" headerText="Datum" width="80"
      <mx:DataGridColumn dataField="hoog1" headerText="Tijdstip van hoog water" width="105"
      <mx:DataGridColumn dataField="laag1" headerText="Tijdstip van laag water" width="105"
      <mx:DataGridColumn dataField="hoog2" headerText="Tijdstip van hoog water" width="105"
      <mx:DataGridColumn dataField="laag2" headerText="Tijdstip van laag water" width="105"
      </mx:columns>
      </mx:DataGrid>
      <mx:Text text="Bron: Bestuurseenheid Mathematisch Model van de Noordzee mumm.ac.be" color="#CCCCCC" width="448" y="170" left="0"
      <mx:Button label="Gegevens inlezen" y="170" right="0" click="test.send()"
      </mx:Canvas>
      </mx:TitleWindow>
      It works fine
      <mx:TitleWindow
      title="
      Getijdentabel (Oostende)" xmlns:p="*" width="734" height="258" creationComplete="test.send()" initialize="test.send()" verticalScrollPolicy="off" horizontalScrollPolicy="off" showCloseButton="true" close="PopUpManager.removePopUp(this);"
      <mx:Script>
      <![CDATA[
      import
      import
      import
      import
      mx.controls.Text;
      import
      mx.controls.Alert;
      Bindable
      private var
      for(var
      //test.lastResult.rss.channel.item[i].description = test.lastResult.rss.channel.item[i].description.slice(620,625);
      if(test.lastResult.rss.channel.item[i].description.slice(536,539) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(541,546);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(618,623);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(722,727);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(771,776);
      if(test.lastResult.rss.channel.item[i].description.slice(535,538) =="ter"
      test.lastResult.rss.channel.item[i].hoog1 = test.lastResult.rss.channel.item[i].description.slice(540,545);
      test.lastResult.rss.channel.item[i].laag1 = test.lastResult.rss.channel.item[i].description.slice(617,622);
      test.lastResult.rss.channel.item[i].hoog2 = test.lastResult.rss.channel.item[i].description.slice(720,725);
      test.lastResult.rss.channel.item[i].laag2 = test.lastResult.rss.channel.item[i].description.slice(769,774);
      </mx:Script>
      <mx:columns>
      </mx:columns>
      </mx:DataGrid>
      </mx:Canvas>
      </mx:TitleWindow>
      It works fine on my computer, but it fails when I've uploaded it to the server. Any hints to solve this problem? Bear in mind I'm not a professional programmer.
      Have a nice weekend,
      Bart
      Geography and sciences teacher
      PS. I added
      <mx:Button label="Gegevens inlezen" y="170" right="0" click="test.send()"/> but even this won't work.
