0 Replies Latest reply on Oct 30, 2009 10:01 AM by jmurphy67
    [svn:fx-trunk] 11311: hook up the building of the playerglobal_rb fat swcs.
    jmurphy67 Level 1
      Revision: 11311
      Author:   jimurphy@adobe.com
      Date:     2009-10-30 10:00:39 -0700 (Fri, 30 Oct 2009)
      Log Message:
      hook up the building of the playerglobal_rb fat swcs.  Currently this will only produce en_US based docs for all languages we are building for.  Once we get translated dita files we will start using them.
      QE notes: all langs will be in English
      Doc notes:
      Bugs: no
      Reviewer: Pete
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/build.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/build.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/__Global__.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/air.update.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.accessibility.xm l
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.data.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.desktop.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.display.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.errors.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.events.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.external.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filesystem.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.filters.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.geom.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.html.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.media.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.drm.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.net.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.printing.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.profiler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.sampler.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.security.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.system.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.engine.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.text.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.ui.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.utils.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/flash.xml.xml
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/packages.dita
      Added Paths:
          flex/sdk/trunk/frameworks/projects/playerglobal/bundles/en_US/docs/authoring.xml
