0 Replies Latest reply on Oct 30, 2009 11:27 AM by rfrishbe
    [svn:fx-trunk] 11316: Fixing VideoPlayer bug: when VideoPlayer is inside a Vbox and is returning from full-screen mode, it RTEs.
    rfrishbe Level 3
      Revision: 11316
      Author:   rfrishbe@adobe.com
      Date:     2009-10-30 11:27:07 -0700 (Fri, 30 Oct 2009)
      Log Message:
      Fixing VideoPlayer bug: when VideoPlayer is inside a Vbox and is returning from full-screen mode, it RTEs.  At this point, the VideoPlayer was a direct descendent of the Application, but now it?\226?\128?\153s getting added back to it?\226?\128?\153s parent.  If that parent is a Halo container and the Application is a Spark Application, it will RTE because the Halo container will try to call removeChild() on the Spark Application.  Instead, I just handle the removing of the component in the VideoPlayer code and call removeElement() when appropriate.
      QE notes: -
      Doc notes: -
      Bugs: SDK-23857
      Reviewer: Glenn
      Tests run: checkintests, mustella VideoPlayer
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23857
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
