0 Replies Latest reply on Oct 30, 2009 2:40 PM by GordonSmith
    [svn:fx-trunk] 11332: Added the beginnings of accessibility support for Spark' s Window and WindowedApplication.
    GordonSmith Level 4
      Revision: 11332
      Author:   gosmith@adobe.com
      Date:     2009-10-30 14:40:07 -0700 (Fri, 30 Oct 2009)
      Log Message:
      Added the beginnings of accessibility support for Spark's Window and WindowedApplication.
      The new WindowAccImpl and WindowedApplicationAccImpl classes live in airframework.swc, not spark.swc, because this is where Window and WindowedApplication live. All AIR components for both MX and Spark are in airframework.swc, which gets compiled against airglobal.swc rather than playerglobal.swc in order to get AIR-specific classes like NativeWindow.
      The trunk has AIR 1.5.2, which is the current version. This version has classes like AccessibilityImplementation, but they aren't operational; there is no actual MSAA support. However, AIR 2.0 will support MSAA, so accessibility code compiled against 1.5.2 should start to work in 2.0.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Evtim
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/WindowedApplication. as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/accessibility/
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/accessibility/WindowAccImpl.as
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/accessibility/WindowedApplicati onAccImpl.as
