This content has been marked as final.
Show 2 replies
1. Re: Auto Trace issue
Mylenium Oct 31, 2009 2:31 AM (in response to jens0771)Any block artifacts in there? Did you reposition the layer? Could simply be a problem with teh content being so near the edges which may prevent some internal operation of the trace algorithm (buffer expansion and smoothing, more specifically). Could also be, that you simply exceed the number of points per mask. It looks pretty dense already. I would try this with more loose settings and possibly pre-compose the contour, moving it more toward the middle.
Mylenium
2. Re: Auto Trace issue
jens0771 Nov 6, 2009 2:45 PM (in response to Mylenium)So, I've shrunk the size down so the person is dead center and smaller and still same problem. What's weird is that it's even tracing things that are "off the screen". I'm really not sure what's going on.
