0 Replies Latest reply on Oct 30, 2009 6:04 PM by kevinklin
    [svn:fx-trunk] 11346: Fix for https://bugs.adobe.com/jira/browse/ SDK-23003 and https://bugs.adobe.com/jira/browse/SDK-23044.
    kevinklin Adobe Employee
      Revision: 11346
      Author:   klin@adobe.com
      Date:     2009-10-30 18:04:34 -0700 (Fri, 30 Oct 2009)
      Log Message:
      Fix for https://bugs.adobe.com/jira/browse/SDK-23003 and https://bugs.adobe.com/jira/browse/SDK-23044.
      -Changed all highlights/lowlights in Button skins to be a full-sized Rect with a gradient fill mimicking the old highlight/lowlight. The old highlights and lowlights would show up as "halos" around the button when cornerRadius was applied and was in focus. However, since it is based on ratios, large buttons will see a change in appearance; the fills will be about half the height of the button.
      -Applied a similar change to the down state stroke to allow cornerRadius to have an effect.
      -Small fix to few skins that were applying cornerRadius to both sides of the button (ex. mx/skins/spark/ButtonBarFirstButtonSkin.mxml)
      QE notes: Lots of bitmap regeneration. See Joann for details
      Doc notes: No
      Bugs: SDK-23003, 23004
      Reviewer: Glenn
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23003
          http://bugs.adobe.com/jira/browse/SDK-23044
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/AccordionHeaderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarFirstButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarLastButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarMiddleButtonSki n.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/EditableComboBoxSkin.mxm l
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PopUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TabSkin.mxml
