1 Reply Latest reply on Oct 31, 2009 4:18 AM by paul.williams
    How to set 2 dataProviders for 1 dataGrid?
    petousas Level 1
      <mx:DataGrid x="750" y="365" id="dataGrid2"  dataProvider="{deleteCouponResult.lastResult}" width="240">
                <mx:columns>
                     <mx:DataGridColumn dataField="msg" headerText="message"/>
                </mx:columns>
           </mx:DataGrid>
      The above dataGrid is used as a feedback area where i fill it with message from database operations like
      "Item succesfully inserted", "Can't insert item", "Deletion succesfull"...etc
      By this time i can only assign one callResponder to my dataGrid but i want also to these:
                <s:CallResponder id="getAllCouponsResult"/>
                <s:CallResponder id="setCouponResult"/>
                <s:CallResponder id="insertCouponResult" />
      My first thought wat to play with binding through actionscript but the below code worked only in the second time add button clicked
      protected function addButton_clickHandler(event:MouseEvent):void
           dataGrid2.dataProvider = insertCouponResult.lastResult;
           insertCouponResult.token = couponsController.insertCouponAction(coupon);
           refresh();
      thanks you very much
      Using Flash Builder 4beta2 with flex 4
        • 1. Re: How to set 2 dataProviders for 1 dataGrid?
          paul.williams Level 4
          Create a private variable in your component:
          [Bindable]
          private var gridData : ArrayCollection; // or whatever dataprovider type you are using
          Then set this property in the result event handler of each CallResponder, eg:
          <s:CallResponder
              result="gridData = ArrayCollection( event.result )"/>
          Then bind your grid's dataProvider to this private variable:
          dataProvider="{gridData}
