1 Reply Latest reply on Oct 31, 2009 1:57 PM by 123miguel123
    Problems parsing a soap-xml result
    123miguel123
      Hi there!
      I got the following result (a soap based XML)
      <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
        <soap:Body>
          <StatusResponse xmlns="http://www.miweb.com">
            <StatusResult>
              <result>
                <Status>1</Status>
              </result>
            </StatusResult>
          </StatusResponse>
        </soap:Body>
      </soap:Envelope>
      When I try to parse it I can't do it, I use the following lines:
           var myXML:XML = new XML (event.result.toString());
           var otro:XMLList = myXML.descendant("Status");
             for each (var item:XML in otro) {
                       trace (item.toString());
      Nothing is showed in the console window
      If I change some labels it works, like this:
      <a>
        <b>
          </StatusResponse>
            <StatusResult>
              <result>
                <Status>1</Status>
              </result>
            </StatusResult>
          </StatusResponse>
        </b>
      </a>
      With this I get the value: 1 in the console window
      What's the problem in here?
      Thanks in advance
