4 Replies Latest reply on Nov 8, 2009 3:23 AM by mohammed.fci86
    Please, I need help in this,How to make a tree control appear from right to left ??
    mohammed.fci86
      i working on Arabic project in which we use a tree control and i  want it to display its branches from right to left .
      i tried to rotate it but it doesn't work because the disclosure triangle still appear on the left .
      i ask if there is any thing to mirror the tree control ,and ask if this mirroing will work or not?
        • 1. Re: Please, I need help in this,How to make a tree control appear from right to left ??
          paul.williams Level 4
          You'll need to modify the layout logic of your renderer.
          Here's a simple example that extends the default tree renderer and overrides the updateDisplayList method(). It will probably need more work. Set textAlign="right" on your Tree control when you use this renderer. You'll also need to supply a disclosure icon that points in the opposite direction.
          package
              import mx.controls.treeClasses.TreeItemRenderer;
              import mx.controls.treeClasses.TreeListData;
              public class RightToLeftTreeItemRenderer extends TreeItemRenderer
                  override protected function updateDisplayList(unscaledWidth:Number,
                                                            unscaledHeight:Number):void
                      super.updateDisplayList(unscaledWidth, unscaledHeight);
                      var startx : Number = data ? TreeListData( listData ).indent : 0;
                      startx = unscaledWidth - startx;
                      if ( disclosureIcon )
                          disclosureIcon.x = startx - disclosureIcon.width;
                          startx = disclosureIcon.x;
                      if ( icon )
                          icon.x = startx - icon.width;
                      if ( label )
                          label.x = 0;
          • 2. Re: Please, I need help in this,How to make a tree control appear from right to left ??
            mohammed.fci86 Level 1
            I tried to define an object of your class RightToLeftTreeItemRenderer and give it to the property itemRendererbut it generates this error
            Implicit coercion of a value of type RightToLeftTreeItemRenderer to an unrelated type mx.core:IFactory.
            and i can't convert it impicitly .
            so,if you can help me with more explaination to how to use this renderer.
            Thank you for your interest
            • 3. Re: Please, I need help in this,How to make a tree control appear from right to left ??
              In MXML:
              <mx:Tree
                   itemRenderer="RightToLeftTreeItemRenderer"/>
              In Actionscript:
              myTree.itemRenderer = new ClassFactory( RightToLeftTreeItemRenderer );
              • 4. Re: Please, I need help in this,How to make a tree control appear from right to left ??
                Thank You very much
                Best Wishes
                mohammed shaaban
                Flex Developer
                MarefaTech
                Egypt
