1. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
John Joslin Nov 1, 2009 7:38 AM (in response to Robert Eckerlin)Use trial and error.
You need lots of both.
And, when you think you've got it licked, it bites back.
... or logs you out.
2. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
D Fosse-QDEaQ1 Nov 1, 2009 7:51 AM (in response to Robert Eckerlin)I think I have it nailed now:
Click to position the cursor, and it appears two lines down and 8 characters to the right. Click nd it disappears altogether. Keep typing, and observe the text appea
and hit the "post" bring in the middle of an unrelated sentence in the next paragraph. Position the invisible cursor to delete the recently typed text, and notice how the preceding sentence disappears.
Close the browser window, open a
to position it again, a
nother and try again. Type the following words: f**k this, utton. It won't matter, because you'll be logged out anyway.
3. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Jochem van Dieten Nov 1, 2009 8:07 AM (in response to Robert Eckerlin)Robert Eckerlin wrote on 11/1/2009 4:31 PM:
I am desesperate to understand how quite basic functions (just as one of many examples: how can I paste text, that I have foremated in MS Word and want to paste into a Forum Post-Entry)
Copy-paste of formatted content is not supported.
Where can I find a User-Guide for this Text Editor?
http://www.jivesoftware.com/builds/docs/clearspace/2.5.7/ClearspaceHelp.html#CreatingConte nt
4. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Robert Eckerlin Nov 1, 2009 9:47 AM (in response to Jochem van Dieten)Thank You Jochem for your answer.
I took a look at the xxxxx.ClearspaceHelp.html Webpage that you refered me to.
I have problems to understand how that Webpage can be considered to be/contain a "User Guide" for the Text Editor.... It contains so few information about Text Editing. Is there really nothing better? Based on your answer, I fear that I can not find or get better documentation from Adobe or from the Jive company about this Text Editor.
5. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
John Joslin Nov 1, 2009 10:19 AM (in response to Robert Eckerlin)solon48 wrote:
I fear that I can not find or get better documentation from Adobe or from the Jive company about this Text Editor.That's par for the course.
You'll get used to it Robert.
6. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Jochem van Dieten Nov 1, 2009 12:22 PM (in response to Robert Eckerlin)Robert Eckerlin wrote on 11/1/2009 6:48 PM:
It is the only thing that is available.
Do you have any examples of the sort of documentation you want to have?
7. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Jacob Bugge Nov 1, 2009 12:43 PM (in response to Robert Eckerlin)This is a test of a few of the options in WordPerfect:
‒ Number one;
‒ Number two.1) Number one again;
2) Number two again.Centred
Right aligned
Left aligned Centred Right aligned
The listings work, unexpectedly.
The alignments do not, expectedly since this is something like emailing. It even strips the font.
This is less worse than expected. So it would be possible to write the whole post and insert, without going through Notepad.
It may be different with Worst, because it is Worst.
8. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Robert Eckerlin Nov 1, 2009 6:31 PM (in response to Jochem van Dieten)Thank You Jochem
I was trying to understand how I could do things as simple as inserting text that I had previously copied. Since there are neither command menüs nor buttons for the Insert of previously copied text, I was trying a mouse right click.....and was being offered in the context menu the choice between "Insert Link", "Insert Image", "Alignement", and "Insert Table"....... but no possibility of a plain insert of previously copied text.
Now, I realize, that Clearstream supports at least the keyword shortcut of "Ctrl V" ........that I am not using in any other software (I never use any keyboard shortcuts).
Since Clearstream does not support reasonable choices in the contextual menus, I will need to memorize the most important keyword shortcuts.By the way: I detected now, that the "Ctrl V" keyboard shortcut allows me to insert formatted text.
Even, if I will now begin to be able to use reasonably Clearstream, I am quite surprised to see that such a software provides neither reasonable Contextual Menus, nor a User Guide, nor........
Thank you again Jochem for your patience with me.
9. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Robert Eckerlin Nov 1, 2009 6:37 PM (in response to Robert Eckerlin)Since Adobe will surely ask Jives to get re-imbursed for the many many hours, that Adobe users have wasted with Jives Software: I will recommend to Hedge Fund Managers to "Short" the Shares of Jive. This will hopefully allow to get rid of some problems.
10. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
John Joslin Nov 1, 2009 10:46 PM (in response to Robert Eckerlin)solon48 wrote:
I never use any keyboard shortcutsIt's time you did, and not because of the awful nature of jive's text input box, but because in all applications a judicious mixture of mouse actions and keyboard shortcuts will speed up operations considerably.
The common ones soon become second nature.
It also helps if you find one day that your mouse is kaputt!
11. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
~graffiti Nov 2, 2009 9:23 AM (in response to John Joslin)John Joslin wrote:
Not to mention it helps avoid carpal tunnel, bursitis and tendonitis.
12. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
shunithD Nov 2, 2009 10:21 AM (in response to John Joslin)John Joslin wrote:
solon48 wrote:
I never use any keyboard shortcutsBut who is solon48? No post here by said person... unless these JIve forums have started playing jive ghosties as well?
13. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
John Joslin Nov 2, 2009 10:54 AM (in response to shunithD)It is Robert E.
Like a few other users he has an alter EGO (or two IDs).
Latin joke.
All part of the plot to frighten everyone away.
14. Re: Where can I find a user-guide for the awfull Text-Editor used to enter/edit these forums entries?
Robert Eckerlin Nov 2, 2009 11:57 PM (in response to John Joslin)No, No...it did not want to frighten anybody away (even if I wanted to do so, I would not be able to do it). Also, I did not want to hide from others or confuse others.
My Forum- or Adobe- profile contained a "Screen Name" and it is that Screen Name that caused the confusion. Sorry for it. Its now fixed.
