8 Replies Latest reply on Nov 2, 2009 4:44 PM by Printer_Rick
    how to create graniet
      I got a box and i want to make the border a gradinet and not one solid color. How can I do this?
      Here is the border I am talking about:
        • 1. Re: how to create graniet
          Doug Katz Level 4
          Well, what do you want to make? A graniet or a gradinet?
          • 2. Re: how to create graniet
            ziftynifty Level 1
            a gradinet. I want that border to be  gradinet.
            • 3. Re: how to create graniet
              Jacob Bugge MVP & Adobe Community Professional
              If you wish to make a simple gradient from side to side of the rectangle or similar and the border is a stroke no fill path (you may copy the path if it is a stroked and filled rectangle, remove the fill of the copy, and work with the stroke), you may Object>Path>Outline Stroke and apply the gradient.
              If you wish something else, there is a different solution for that, too.
              • 4. Re: how to create graniet
                JETalmage Level 6
                I think he wants a grainy ET.
                • 5. Re: how to create graniet
                  M0man Level 1
                  Personally, I don't believe there is any easy way to accomplish this, But I may be wrong.
                  I would create 2 rectangles, One slightly larger and underneath the smaller of the two, Remove the stroke, And fill it with a Gradient. Then fill the rectangle on top with a white. Unless you required the stroke to be a gradient, This should work.
                  If you have any questions, I'll try my best to help.
                  • 6. Re: how to create graniet
                    Scott Falkner Level 5
                    Without breaking a sweat I can think of three different ways to envision a gradient applied to the stroke of a rectangle. Each is different, each can be called a gradient, and each can be achieved a number of ways, none of which is applicable to another.
                    Which of these gradients is what you are after?
                    • 7. Re: how to create graniet
                      Cheryl Graham Level 2
                      You can make a "gradient brush" and apply the brush stroke to the rectangle border. Here's a how-to:
                      • 8. Re: how to create graniet
                        Printer_Rick Level 4
                        1. Window: Gradient, and define your gradient
                        2. Draw a box with white fill no stroke
                        3. Window: Appearance, Add New Fill
                        4. Double Click on lower fill in Appearance. Then click on the gradient color in Gradient Panel.
                        5. In FX flyout at bottom of Appearance, Convert to Shape, Rectangle, select Relative and specify thickness of border
                        You now have white box with gradient border.
                        Also note: if you need the white fill to be none, no problem. With box selected, in Appearance, select the white fill and change Opacity to Multiply. The white will disappear but that's OK. With the item still selected, Object: Group.
                        Now, Window: Layers: New Layer. Click the little circle icon beside this new layer in Layers Panel. In Appearance click on Opacity, then check "Knockout Group".
                        Select the box. In Layers Panel, click on the tiny colored icon beside "Group." Drag this UP to the new layer just created above. This should make your gradient border look correct again.
                        Now click back on the bottom layer. Any art you create here will show through the white box on the layer above, but not the gradient border.
