5 Replies Latest reply on Nov 2, 2009 1:32 PM by pao1011
    Flex compile question
    pao1011
      Since my "New to Flex swf question"  is not answered I try this new thead.
      I try to compile a mxml file to get a swf output. The help document say that I build the file in project>build but the only outputs I get, are my assets folder and the style.css file but no swf or html file. When I run it, as is obious I get an error about "file not found: path to/myfile.html " since I do not have any html created on my output folder. I think the compiler is supposed to build it cause I have set that in pject properties> flex compiler properties.
      Q 1: What the compiler output? the html of the mxml project file or the template that is in the html_template folder when you create the project.
      Q 2: The compiler is supposed to output the swf from the mxml project file or rewrite the playerProductInstall.swf?
      I search the help file, google and the flex forum to similar problem but i did not find anything.
      I hope someone help me with this question.
      Thanks in advance.
        • 1. Re: Flex compile question
          paul.williams Level 4
          If you have "Project->Build Automatically" switched on then as soon as your create a new Flex Project it will be automatically compiled and you will be able to run it. A swf file and an html file will be created in bin-debug.
          Please try this without making any changes to the new project's configuration and confirm you are able to run the application.
          • 2. Re: Flex compile question
            levancho Level 3
            when you get partially built content in bin-debug folder that means there is an error in your code,  so build stops at compile step,
            have a look at errors , which is under problems windows and make sure there are no red icom messages,
            yellows are fine
            • 3. Re: Flex compile question
              pao1011 Level 1
              .thanks for the sugestion and yes I got an error but I think is out of my league since I do not know much about AS. It's an override function that is disabled in the object. I'm using the sample source of the FMS video player so I create another player, just to learn fex but seems is too advance for my knowledge. But if you got any sugestion is greately appeciated
              • 4. Re: Flex compile question
                levancho Level 3
                what does error message say?
                • 5. Re: Flex compile question
                  pao1011 Level 1
                  --1020: Method marked override must override another method. vPlayer/src/fl/video DynamicStream.as line 308 --
                  this is the error code
                  override public function play2(param:NetStreamPlayOptions):void
                  throw new Error( "The play2() method has been disabled for this class. Please create a separate NetStream object to use play2().");
                  I'm recreating the video player from fms,  of course just the components  not the scripting because I'm not good in AS
                  Thanks for responding
