2 Replies Latest reply on Dec 21, 2009 9:01 AM by mrMango58
    Flash cs4 and windows 7( professional) Question
    mrMango58
      I am a rookie. I have a PC with all the necessary clout to run Flash. I have run the program in every mode available, and there are problems with performance.
      There are problems with tools not working (the pencil tool only draws a line upon release) .
      There are problems with importing mp3 files.
      I have installed and reinstalled the suite and nothing changes.
      At this point I am ready to believe that the copy of CS4 I have is somehow corrupt.
      OK I have detailed my frustration what I would like to know is ; Does anyone have a definitive answer as to how to run CS4 in the Windows 7 operating system.
      Has anyone done so without endless problems.
      Does anyone from Adobe have knowledge of the difficulties people are having?
      I'm missing Flash 8
      Mango
        • 1. Re: Flash cs4 and windows 7( professional) Question
          barakadesign
          I have similar problem.  When I first installed everything seemed to work well.  But then Flash began opening slowly and once the properties panel was accessed it became too slow to use. I spoke with adobe support for around an hour and they ultimately told me to reinstall.  I did this with no change in outcome.  I then reinstalled my graphics driver and that improved performance so now I can use Flash, but it is still extemely slow.  I've noted that on the Windows 7 compatibility page Adobe says that CS4 has been tested with Windows 7 Ultimate and everything is fine.  Perhaps it will only run well in virtual xp mode. Other thing that could be a problem is use of a wacom tablet and it's drivers.  I have to reinstall these frequently and there appears to be a conflict with the windows 7 tablet pc features in that on a couple of occasions these have started up with my tablet.
          • 2. Re: Flash cs4 and windows 7( professional) Question
            mrMango58 Level 1
            clearspace
            I suffered with installing and uninstalling. I upgraded drivers.I even
            got the local software store to get me a new copy of cs4.Eventually I
            gave up and now I  duel boot "7" with XP (32 bit). I run the cs4
            programme when  I boot into "XP".It works well.When Adobe develops a
            version that is compatible with 64bit I will upgrade and take advantage
            of the improved performance.
            Mango
