6 Replies Latest reply on Nov 3, 2009 9:18 AM by rafa@mediatech
    Make a toggle button
    rafa@mediatech Level 1
      Hi Everyone,
      I have a button that allows the user to make the stage fullscreen and return it to normal screen. I was wondering how to make this into a toggle button so that it works all across the multiple pages of the project.
      in a movie script I have:
      on mCenterRectInRect r1, r2
        return rect(r2.width - r1.width, r2.height - r1.height, r2.width + r1.width, r2.height + r1.height)/2
      end
      then, the enlarge screen button has:
      on mouseUp me
        dr = (the desktopRectList)[1]
        sr = (the stage).sourceRect
        tWidthRatio  = float(dr.width )/sr.width
        tHeightRatio = float(dr.height)/sr.height
        ratio = min(tWidthRatio, tHeightRatio)
        tWidth  = sr.width  * ratio
        tHeight = sr.height * ratio
        tDrawRect = mCenterRectInRect(rect(0, 0, tWidth, tHeight), dr)
        (the stage).rect     = (the desktopRectList)[1]
        (the stage).drawRect = tDrawRect
        go to the frame +1
      end
      the "return to normal" button has:
      on mouseUp me
        (the stage).rect = rect(295, 288, 935, 786)
        (the stage).drawRect = rect(0, 0, 644, 503)
        go to the frame -1
      end
      I have used this code in single page projects... but now I need to incorporate it to a multiple page project...
      thank you in advance!
      Rafa.
        • 1. Re: Make a toggle button
          robdillon Most Valuable Participant
          To combine the two functions to be used with one button, you can just add a boolean variable to act as the toggle but... you have a lot going on in the functions that could, and should, be relegated to a beginSprite function. You only need to know the size of the user's screen once, for instance.
          So, how about something like this:
          property thisSprite -- the button sprite
          property makeFullScreen - the boolean to act as the switch
          property dr
          property sr
          property  tWidthRatio
          property  tHeightRatio
          property ratio
          property  tWidth
          property  tHeight
          on beginSprite me
               makeFullScreen = false
          end
          on mouseUp me
               makeFullScreen = not makeFullScreen
               if makeFullScreen then
                   --go to the frame +1
              else
                 --go to the frame -1
              end if
          end
          I commented out your move forward and back by one frame. I have no idea if they will be needed if you combine this code. To make this button work across the entire movie, just extend the sprite to the end of the score.
          • 2. Re: Make a toggle button
            Rob,
            Thank you so much for your help. This is working great. One concern... when the video returns to standard size it is not returning to 800x600 (this is the default size of the project). I thought it had to da with the line that reads:
            else
            end if
            I changed:
            to:
            (the stage).drawRect = rect(0, 0, 800, 600)
            ...but when the user clicks to return to normal, the stage it wasy off the frame of the 800x600 window. Do you know what might be causing this?
            thank you,
            Rafa.
            • 3. Re: Make a toggle button
              The rect property is the position of the stage on the user's computer screen. The drawRect is the size of the stage in that window space. Ideally they should be the same dimensions, but probably not the same values. In your code the rect is 640 X 498 and the first drawRect is 644 X 503 and the second is 800 X 600. The first is closer. Try using 640 X 498, or whatever the original size of the stage was.
              • 4. Re: Make a toggle button
                Rob,
                That still shows the stage offscreen (and screen not 800x600). I went to the "message window" and typed:
                put (the stage).drawRect
                It returned:
                rect(57, 40, 857, 640)
                When published this way the project still shows offscreen and window is not 800x600 (after toggled back to normal screen). I inserted the dimensions you suggested:
                (the stage).drawRect = rect(57, 40, 640, 498)
                ... but now the stage is more centered (not completely) and stage is still smaller than 800x600 (after toggled back to normal screen). How can I get my project's original window size and stage position and tell it to return to this specifically?
                thank you,
                Rafa.
                • 5. Re: Make a toggle button
                  Got it!
                  I created two new properties:
                  property origSize
                  property origPos
                  defined them on:
                  on beginSprite me
                    origSize = (the stage).rect
                    origPos = (the stage).drawRect
                  end
                  ...and use them on the else if:
                  else
                      (the stage).rect = origSize
                      (the stage).drawRect = origPos
                  end if
                  this seems to be working porperly!
                  Thanl you Rob!
                  Rafa.
                  • 6. Re: Make a toggle button
                    Thank you for your help Rob.
                    Rafa.
